Hello everyone,
I'm new to this forum, but I've actually been using a diagnostic system for a few years now and have occasionally read posts here.
So far, I haven't had any significant problems with the car. Reading posts and technical articles has always been sufficient support for me in answering any questions. My experience working on diesel engines, which I've mainly gained (also due to the car's inconspicuous nature), has primarily been with older tractors.
Currently, I'm experiencing a problem with my vehicle that I'm unable to resolve on my own, which is why I'm deciding to sign up.
Here's a brief description of the vehicle: Volkswagen Golf IV Variant, manufactured in July 2002, engine code AXR, gearbox code EUH.
The engine control unit has had a modified data set for operation with vegetable oil since 2005 (approximately at 50,000 km). In any case, the fuel injection timing map was adjusted (shifted earlier), the exhaust gas recirculation system was modified (with a high target air mass, effectively resulting in zero recirculation), and the coolant temperature sensor characteristic curve was changed (starting at approximately 40°C, it corresponds to the actual value; before that, significantly lower temperatures are indicated, which shifts all temperature-dependent maps accordingly during warm-up).
Regarding the driving behavior and control mechanisms, I have not been able to detect any differences after the dataset was changed, which is why I do not want to pursue further modifications - there are other forums for that.
Regarding the issue:
At the end of February, a free repair shop replaced the head gasket on the vehicle, which had approximately 200,000 km on it. The vehicle had overpressure in the cooling system, resulting in water leakage from the expansion tank. During this repair, the cylinder head was disassembled, machined (specifically, the cylinder surfaces were honed), and reassembled. The PD (common rail) injectors were supposedly sealed and adjusted by VW, and the wiring harness was replaced.
Since the repair, the vehicle has experienced a significant loss of power across the entire RPM range. However, the engine runs smoothly (direct cold start with fuel enrichment, no hesitation, no vibrations, no visible misfires across the entire RPM and load range). The engine control unit (ECU) does not show any error codes. The problem and the tests already performed are largely comparable to this topic.
/viewtopic.php?t=26280
The first workshop (independent) has so far:
- The ZKD (crankshaft position sensor) was replaced again (with a thicker one).
- Field measurements were conducted.
A second workshop (Volkswagen) continues:
- The function of the boost pressure control and the mass airflow sensor were positively tested.
- Basic adjustments were performed on the AGR (Abgasrückführung - exhaust gas recirculation) and turbocharger pressure control systems.
- Checked the valve timing (OK).
- Compression measured (approximately 17 bar, with a difference of 2 bar, which was assessed as borderline).
I have:
- Checked the valve timing according to the instructions from this forum.
--> Within acceptable limits, +/- 3 degrees, indicating no change.
- Checked the settings of the PD elements following instructions from this forum.
--> UT, then open 180 degrees, and it works everywhere.
- Fuel return line disconnected before the diesel filter and held in a container.
--> Bubble-free, clear, consistent stream, fills a 0.4L glass in 30 seconds.
- Refueled after 400 km.
--> The MFA (Multifunction Display) indicates a fuel consumption that is 45% higher than the actual consumption when refueling at night.
- Own measurement test conducted (see attachment).
I have the impression that the injection quantities calculated and displayed by the MSG (presumably a diagnostic tool) do not actually reach the combustion chamber in reality, and this is not just in the area of maximum power, but over a wide range of engine speeds and loads. For example, the power loss is already noticeable during maneuvering at idle speed, where the mass airflow sensor (LMM) and throttle position (TL) are not yet playing a major role. Under load, the fuel consumption display rises rapidly (perhaps too quickly) to values of 4-5 liters per hour, and the engine shuts off just as quickly. Similarly, the car accelerates sluggishly even on the acceleration lane in 3rd gear, where, according to my measurements, the air mass, boost pressure, and injection quantity should be more than sufficient.
Based on these observations, I initially didn't plan to replace any parts in the surrounding area. In my opinion, components like the turbocharger, boost control valve, mass airflow sensor, intercooler, and EGR valve are unlikely to be the cause of the problem.
My next step would be to explore tandem pumps or positive displacement elements, and in a first step, measure the pre-charge pressure of the positive displacement element. However, so far, no workshop has come forward to help with this.
Is there a way to verify the actual amount of fuel injected by the PD injectors?
So far, the electrical control of the PDE (presumably a "Pressure Drop Element" or similar) has also remained completely unclear. Is it possible to get any useful information using a standard multimeter, or is it necessary to use a storage oscilloscope due to the rapid control signals?
Thank you in advance for reading and for your ideas.
Stefan.
