Flashing light bulb, even though everything seems to be working fine?
Fuschi68
Post05-08-2003, 18:46    Subject: Flashing light bulb, even though everything seems to be working fine? Quote
Hello everyone,
I've found something strange in my 1-bedroom apartment again.
I was on the highway today and suddenly the warning light started flashing. Strangely, I didn't really notice any changes in how the car felt. Should the EDC not be running in emergency mode?
Then I pressed the brake, and the turn signals stopped. However, they reappeared regularly as long as I didn't press the brake for 4 minutes. After the problem reappeared, I gently pressed the brake pedal, and the light went out.
What does this indicate, if anything, given that nothing else went wrong except the unusual fact that it was between 35 and 40 degrees Celsius today? When have we had such hot days in Germany before? The cooling system also didn't work when the speed exceeded 160-170 km/h, and the engine temperature rose to 100 degrees. I'll be coming down off the gas soon.
Therefore, here are two questions:
Is it normal that a TDI is not designed for such high outdoor temperatures? What are they doing in southern countries?
And can this be related to the blinking light bulb, or does the above description point to something else?
Thank you in advance for your great help on this topic. It has already been very helpful to me many times. By the way: My self-mounted timing belt pulley on the self-repaired KW stump is working like new.
Markus
PS: Ugh, my climate control has been broken for two years icon_sad.gif(( *sweating, dripping*
Mc_Givertechnik
2010 Volkswagen T5
Post05-08-2003, 19:37    Subject: Flashing light bulb, even though everything seems to be working fine? Quote
Hello!
With my Galaxy, I experienced the same symptoms: flashing lights, sudden braking, and then the lights stop.
Cause: The switches on the clutch pedal and the brake pedal were not compatible with each other in terms of their settings. One contact was open and the other was closed. If this has been the case for a while, the indicator light (blinks).
At the Ford dealership, the mechanic then re-set the switches using the diagnostic tool. This should also be possible with VAG COM, but I haven't done it myself and therefore can't give you any specific information. The switches definitely have adjustable pens in length, with which the point for the closed contact can be set.
It's Peter saying hello.
VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
No new posts Glow plug control Diesel Engine Technology
This topic is locked, you cannot edit or reply. Glow Plug A3 1.6 TDI: Troubleshooting & Repair Diesel Engine Technology
No new posts Bad Climate: Causes and Solutions Diesel Engine Technology
No new posts Cold start is fine, but after a few minutes there's blue ... Diesel Engine Technology
