hame22 Blaumann
31-05-2008, 10:24 Subject: PD Element Design: Creative Typography Solutions |
Hello everyone,
Is there a way to replace the seals on the PD elements?
To be reviewed without being expanded?
Is the LLRR (Leakage Location and Rate Ratio) a sufficient indicator for leaky PD (Partial Discharge) elements?
Translated on 18-09-2026, 10:03.
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
31-05-2008, 11:00 Subject: PD Element Design: Creative Typography Solutions |
No, the only solution is to take it apart.
Translated on 18-09-2026, 10:04.
Profile PM WWW Garage |
hame22 Blaumann
01-06-2008, 10:54 Subject: PD Element Design: Creative Typography Solutions |
Hello Rainer,
Do you happen to have the part number for that set?
or the price?
wingmaster Blaumann
Joined: 12/25/2007 Posts: 100 Karma: +4 / -0 Location: Köln
01-06-2008, 11:27 Subject: PD Element Design: Creative Typography Solutions |
"038189051C costs €20.29 and is always only for one PD unit."
charlyfirpo Blaumann
Joined: 09/02/2006 Posts: 155 Karma: +6 / -0 Location: DM 2013 Volkswagen Golf Support
dieselschrauber likes this. |
05-06-2008, 20:05 Subject: PD Element Design: Creative Typography Solutions |
Hello.
There is a way to check the O-rings, specifically when inspecting the tandem pump.
Coolant temperature: minimum 85 °C.
Connect the pressure gauge to the test port of the tandem pump.
- Increase the speed to 4000 RPM.
- Observe the pressure displayed on the pressure gauge.
Set point: minimum 7.5 bar.
If the target value is not reached:
- Clamp the return line between the fuel filter and the tandem pump using a hose clamp or pliers.
Is the target value being reached now?
Pressure loss in the pump-nozzle injectors.
- Replace the O-rings of the pump-injector units.
- Replace the tandem pump.
A leak can be detected internally in this way.
Best regards, Charly. Golf 4 GTI TDI, ARL Serie 346031 Km
Webasto Thermo Top E
15.02.2013 -> Golf 6 GTD DSG CFGB/NLN, TT-V+T91R
21.03.2016 -> Golf 7 R, Limestonegrey, 19", Voll...
Translated on 18-09-2026, 10:06.
Profile PM Garage |
hame22 Blaumann
06-06-2008, 20:01 Subject: PD Element Design: Creative Typography Solutions |
Thank you for the response.
How reliable is this test?
Have you ever done this before?
Translated on 18-09-2026, 10:07.
07-06-2008, 8:35 Subject: PD Element Design: Creative Typography Solutions |
Hello.
I've done this before. However, in my case, it was to test my insulin pump.
For reliability: Source VAG.
Translated on 18-09-2026, 10:08.
Profile PM Garage |
Biggi
Registered VCDS User
16-04-2012, 21:42 Subject: PD Element Design: Creative Typography Solutions |
Hello, where can I get a pressure gauge like that, and what kind of connection does it have?
Gremlin Schrauber
Joined: 08/18/2005 Posts: 395 Karma: +91 / -0 Location: Grainet 2000 Audi A4 Avant  Premium Support
17-04-2012, 3:14 Subject: PD Element Design: Creative Typography Solutions |
For the VW Transporter T5 AXE (R5 TDI), it's a M12x1.5 connection. It might be the same for you, but I can't guarantee it!
I built the fitting myself: I connected it with a threaded fitting, a Festo hose, and a standard pressure gauge up to about 15 bar.
Translated on 18-09-2026, 10:09.
Profile PM Garage |
