I would like to replace the nozzle inserts on my BMP. I wanted to do this according to Rainer's instructions: https://community.dieselschrauber.org/en/viewtopic.php?t=17583
and I've found that the outer sleeve probably comes in several versions.
Rainer uses a 19mm ring wrench in the video he posted. My PD elements have locking nuts with an 8-sided shape and a keyway of 20mm.
Does anyone know where I can get a Bosch or Vag key? And does anyone happen to have the part number?
@ Herbert
Yes, it's an 8-sided (hexagonal) socket. I also couldn't find anything like it at Hazet.
@ Autoservice: I've already tried the clamping method, but I'm having trouble.
Aborted because I couldn't tighten the sleeve enough in the vise.
"I can't get them out of their round shape ."
