Climate Evaporator Lines
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
BERT
Post09-08-2003, 15:24    Subject: Climate Evaporator Lines Quote
Hi there,
mal wieder ein typ. Summer theme!
- Refrigerant: Empty after approximately 2 weeks of topping up.
-> Evaporator slightly leaking (contrast agent at the condensate outlet).
'The aluminum cable conduit was almost completely pushed through the dryer due to its ingenious routing along the coolant hose.'
Question: Is there a way to repair the vaporizer? (Model: KV 418E, without the 'Mafia' modification). Someone mentioned something about the cooler before.
Has anyone ever removed the dashboard and disassembled the heater box on a Sharan MJ98 AFN model? VAG claims it takes a whole working day to do that!
Translated on 22-07-2026, 4:12.
WarLord
Post09-08-2003, 17:26    Subject: Climate Evaporator Lines Quote
Regarding the vaporizer: Perhaps you could take it to a local appliance repair expert; they might be able to fix it, and it wouldn't necessarily be expensive. Otherwise, check eBay.
Best regards, WarLord.
Translated on 22-07-2026, 4:13.
ManicMechanic
Post10-08-2003, 21:21    Subject: ShaGalAmbra Vaporizer Quote
Hi!
The evaporators (at least in the Alhambra models) were breaking down one after another. Seat then replaced them under warranty/goodwill, but that's likely impossible to get after 5 years (although there was probably a design or manufacturing defect involved).
Removing and installing the dashboard is a very difficult job...
'cu' translates to 'see you' or 'goodbye' in Spanish. It can also be used as a greeting, similar to 'hi' or 'hello.'
Manicmechanic.
Translated on 22-07-2026, 4:14.
No new posts Audi A3 TDI AC Fan - 1st Speed Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wo ist der Verdampfer der Klima? Transmission, Chassis, Body & Interior
No new posts Common-Rail Leitungen 2,7l und 3,0l V6 TDI nicht vertauschen Diesel Engine Technology
This topic is locked, you cannot edit or reply. Temperature sensor, evaporator, Passat 3BG 4Motion, 2.8L Transmission, Chassis, Body & Interior
No new posts Find the target resistance of sensor g308 (on the atomizer) Electrical Systems, Vehicle Electronics, Multimedia
