"I've been having a problem since yesterday. The car was running perfectly fine the day before yesterday, but since yesterday, it has a noticeably rougher engine running. You can especially feel it when accelerating, as there are vibrations in the gas pedal and the gear stick."
Furthermore, there's a slight jerk when releasing the accelerator, and a harsh load change when pressing the accelerator – especially when, for example, you need to brake uphill and then press the RES button on the cruise control, and it immediately starts accelerating with a high fuel injection rate.
I noticed this yesterday after driving over a rougher dirt road, but I don't think it's related.
The following parts are new or in like-new condition:
- The engine mounts and transmission mounts are new.
- The torque strut is relatively new, with only 40,000 km on it, but the engine is solid and secure.
- The entire suspension has essentially been overhauled, meaning that components like ball joints, tie rod ends, control arm bushings, shock absorbers, strut mounts, etc., have all been replaced in the last year.
- The clutch and dual-mass flywheel were replaced approximately 20,000 km ago.
- No issues whatsoever with the engine, fuel consumption between 5.1 and 5.9 liters, flawless acceleration, etc.
- No error codes found.
- LL alignment is acceptable (-0.75; 0.25; -0.24; 0.7
A few months ago, the right outer bearing of the A-axis was seized, which was noticeable due to significant imbalance. It was removed, cleaned, repaired, and reinstalled with a new seal at a specialized workshop. Since then, the problem has essentially disappeared.
The only thing I've noticed repeatedly is this: I park facing forward, then when I drive backward, turning the steering wheel, I hear a "clack" sound. This clacking sound, coming from somewhere in the front axle area, happens regularly. At first, I suspected a broken spring, so I replaced the strut mounts, but the problem persists.
Could all these symptoms actually be related to a completely worn-out A-arm joint? Since this part isn't readily available as an accessory for the 4x4 and costs around €180 from the original manufacturer, I'm reluctant to invest that much money "just in case."
Or do you have any other suggestions?
Greetings.
