VCDS-RKS: Version 11.11.2 Update & Features
Post11-01-2012, 21:49    Subject: VCDS-RKS: Version 11.11.2 Update & Features Quote
For those who haven't noticed yet: There is a new software release from VCDS available in the customer account section of the shop.
New features in version 11.11.1:
New feature: Support for new models: VW Beetle (5C/AT), VW up! (12/AA).
New feature: ECU image adaptation for ECUs with the ASAM/UDS protocol.
Improvement: Optimization of the stability of ongoing diagnostic sessions.
"Update: The USB driver update from Beta versions 11.8 and 11.10 has been withdrawn. Communication errors may have occurred with the USB drivers included in the beta versions. A new update is planned once error-free drivers are provided by the supplier. The new driver was necessary because, in some cases, connecting the interface hardware to newer PCs/laptops resulted in a blue screen error. If you experience this issue, please contact your sales partner immediately."
ECU documentation (label files and ODX/ASAM data specification) expanded/updated.
New features and improvements in release 11.11.0:
"New Feature: Support for VW Crafter (2E). All installed VW control units are fully supported (including fault memory, measured values, basic settings, coding, adaptation, etc.). For the installed Mercedes control units, a limited range of functions is currently available, including fault memory reading/clearing and the adaptation function (e.g., resetting service intervals)."
New feature: Enable/disable transport mode support for current models such as the Audi A6/A7 (4G), A8 (4H), and VW Touareg (7P).
New feature: Ability to read engine mileage from the Engine Control Unit (ECU) for 2.5L V6 TDI engines (EDC15).
"New feature: Display of the label file used for subsystems. The diagnostic log (auto-scan) now indicates whether a label file is assigned to a subsystem."
"New feature: Additional display of more information regarding the initial setup. During the initial setup process, additional information about the steps involved and/or prerequisites will now be displayed."
New feature: New data types for OBD2/EOBD mode 9 and OBD2/EOBD corrections.
New feature: Support for new ECU addresses.
"Improvement: The ODX/ASAM data has been completely revised. By changing the data structure, much of the previous redundancy within the data has been eliminated, resulting in a drastic reduction in file and download sizes. At the same time, many new models/ECUs have been added, allowing for better coverage of newer models such as the current Audi A6/A7 (4G)."
Revised error code display: The presentation now varies depending on the communication protocol, making it significantly more informative, especially for new protocols/ECUs. Additionally, users can now choose whether to read the fault memory in "normal" or "aggressive" mode.
Improvement: Airbag coding assistant revised.
Improvement: LCode revised. Thanks to Niels Ezerman.
Improvement: CAN TP 2.0 connection establishment has been revised and stabilized.
Improvement: Measurement display corrected for some newer Audi radios.
Improvement: Expanded display of subsystems during the vehicle scan.
Numerous further corrections and improvements.
Error code list revised and expanded (now includes over 17,400 error codes).
KDataScope has been updated and now supports even more corrupted CSV files, utilizes screen space more efficiently, and includes a basic 3D visualization feature.
The previous add-on programs such as KPower, KPerformance, and KFuel are, of course, still included.
VCScope was modified by Eric Maurier to handle measurement blocks greater than 255, and I have incorporated those changes.
Download under http://shop.dieselschrauber.de/ "Your Account"
 VCDS 11.11.1, RKS Distribution
 File size:  58.65 KB
 Viewed:  7380 times
Translated on 28-07-2026, 7:48.
Post31-01-2012, 18:08    Subject: VCDS-RKS: Version 11.11.2 Update & Features Quote
There is a bugfix release 11.11.2 that fixes issues with the "Customization" function.
As always, you can download it from your customer account.
Translated on 28-07-2026, 7:54.
Post01-02-2012, 9:15    Subject: VCDS-RKS: Version 11.11.2 Update & Features Quote
I've bolded the parts that refer to sections 11.11.1 and 11.11.2.
I had already wondered why, in version .2, everything that came in version .1 should be considered new again icon_smile.gif.
timmiboy83
Post08-07-2012, 1:42    Subject: VCDS-RKS: Version 11.11.2 Update & Features Quote
Improvement: USB driver update from beta versions 11.8 or 11.10 has been withdrawn. Communication errors may have occurred with the USB drivers included in the beta version. A new update is planned as soon as error-free drivers are provided by the supplier. The new driver was necessary because, in some cases on newer PCs/laptops, connecting the interface hardware resulted in a blue screen. If you experience this issue, please contact your sales partner immediately.
I also experienced the exact same problem with my brand new ASUS laptop. When I called my distributor, he immediately and without even considering it, claimed that my laptop must be defective. When I told him that the laptop was brand new, he said again that it didn't matter, that it was defective.
And all of this is happening over the phone, which is interesting because all other applications and USB devices work perfectly fine on the laptop, but only VCDS and the diagnostic dongle seem to be causing problems, and apparently this is a known issue.
I have the latest update, but unfortunately, the problem still persists. Please help me resolve this. Thank you.
Translated on 28-07-2026, 7:56.
Post08-07-2012, 8:56    Subject: VCDS-RKS: Version 11.11.2 Update & Features Quote
See:
Translated on 28-07-2026, 7:58.
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS 26.9.0 Update: SFD Now Available in German Version On-Board Diagnostics (OBD)
No new posts VCDS 11.11.5 is outdated, VCDS: Software is outdated On-Board Diagnostics (OBD)
No new posts VCDS-RKS 12.12.2: Update & Features On-Board Diagnostics (OBD)
No new posts VCDS-RKS Compatibility with Windows 8 On-Board Diagnostics (OBD)
