haithamina Schrauber
Joined: 05/15/2006 Posts: 666 Karma: +27 / -3 Location: 69221 Dossenheim
19-08-2012, 21:07 Subject: |
haithamina wrote: |
If the mass airflow sensor (LMM) is okay, I suspect the vacuum timing gauge (VTG) or its control system. |
Strike!
haithamina 3G5, 110 kW, DFGA, TGV, Variant HL 2018-
Translated on 30-07-2026, 5:53.
Autoservice Profi-Schrauber
19-08-2012, 22:34 Subject: |
Quote: | Thank you for the solution and an interesting story!
Now we know what log data looks like when the VTG closes too much.
What surprises me the most is that mistakes can be made by anyone, regardless of their expertise; therefore, I have definitely learned something.
Yes, it's interesting and good that the symptoms have disappeared.
Whether the error has now been eliminated, or is merely circumvented by the lower air resistance in the TL, unfortunately remains open.  LG, Onkel BM
Translated on 30-07-2026, 5:54.
20-08-2012, 6:52 Subject: |
Autoservice wrote: | Whether the error has now been eliminated, or is only circumvented by the reduced air resistance in the TL, unfortunately remains open.  | For me, both are the same: the minimum total opening for the exhaust flow (the sum of the areas between all VTG turbine blades) is now increased due to adjusting the set screw, which means that the error cause "exhaust backpressure" can no longer occur.
By the way, it's also interesting that a VTG (vehicle end stop) setting that was significantly misaligned and in the error range can be corrected with an estimated adjustment, even when a loader is mounted, to such an extent that the wagon runs normally again from the first attempt.
Garrett, on the other hand, wants to have all VTGs adjusted at the main factory because even specialized turbocharger companies supposedly can't do it correctly. . .
Or is this information outdated now? Gruß Ulf
Translated on 30-07-2026, 5:56.
Profile PM Garage |
chli1976 Profi-Schrauber
20-08-2012, 8:02 Subject: |
A refurbished turbocharger was installed, but I have no idea which company manufactured it.
Perhaps it would have worked if I had turned it around. But I wanted to be sure whether anything would change. I'll leave it as is now; I've already spent enough hours in the car. VCDS
Translated on 30-07-2026, 5:57.
20-08-2012, 9:02 Subject: |
chli1976 wrote: | A refurbished turbocharger was installed, but I have no idea which company made it.
Perhaps it would have worked with a rotation. | I just wanted to be sure if anything would change.  I'll leave it as is now; I've already spent enough hours in the car.
Unfortunately, I had similar experiences with customer vehicles a few years ago. At a certain point, I started rejecting all chargers that didn't come from a reliable source, or I would only install them if I was paid immediately. }
When dealing with a full workday and a second appointment due to troubleshooting or re-calibration, especially when the loader is actually functioning correctly, it's no longer economically viable to deal with "makeshift loaders." }
Translated on 30-07-2026, 5:58.
Profile PM WWW Garage |
