Wiring diagram for climate control system, G3.1Z
johnny castaway
Post19-08-2003, 14:58    Subject: Wiring diagram for climate control system, G3.1Z Quote
Hello everyone,
'Recently, I had a cable fire in my 1995 G3 Variant TDI with a 1Z engine. Since then, the manual air conditioning system hasn't been working. I've already replaced the pressure sensor. The coolant level is also fine! There's also a two-pin connector 'loose' in the engine compartment. I've also replaced the fuse box.'
Does anyone know if there have been any changes to the fuse box or wiring harness? And can someone get me a wiring diagram? Or does anyone have any other tips?
Thank you very much.
johnnyc
Translated on 22-07-2026, 9:16.
No new posts Kickdown Switch: Diesel & AC System Repair Diesel Engine Technology
No new posts Is the climate compressor blocked? Transmission, Chassis, Body & Interior
No new posts Wasserpumpenwechsel Sharan TDI (klima muß raus?) Transmission, Chassis, Body & Interior
No new posts Running fan? - Audi 80 TDI - 1Z with air conditioning - 1994 Diesel Engine Technology
