Vacuum Pump Disassembly: What Next?
roorback
Karma: +1 / -2   Thank you, like it!
Post29-11-2012, 23:30    Subject: Vacuum Pump Disassembly: What Next? Quote
Hello.
I'm really embarrassed to ask, but there's absolutely no information available about the vacuum pump. I disassembled it, and the valves are out. Based on a photo I found online, I was able to reassemble it to some extent, but I'm stuck on part number 4 – it's a plastic piece, a valve, and a gasket.
Does anyone happen to have a photo, drawing, or any idea of how this goes back together?
THANK YOU
"Hello"
Translated on 09-09-2026, 17:17.
Post29-11-2012, 23:33    Subject: Vacuum Pump Disassembly: What Next? Quote
Please upload a photo of your disassembled pump.
Translated on 09-09-2026, 17:18.
roorback
Post30-11-2012, 8:15    Subject: Vacuum Pump Disassembly: What Next? Quote
Hello.
Sorry, but I don't have a photo available at the moment.
Okay, let me try to explain it again – when you remove the lid of the vacuum pump, you'll see two valves directly. One of them (where the vacuum hose is also connected) is a plastic part, a seal, and behind that is the valve.
It's specifically about these three parts – I spread them out in the garage using some air tools – and I have no idea how they go together anymore.
Normally, I would take pictures or write it down, but this just happened unexpectedly.
Someone might have a photo or information about it – that would be great.
THANK YOU
Translated on 09-09-2026, 17:19.
cumminsracer
Post30-11-2012, 9:59    Subject: Vacuum Pump Disassembly: What Next? Quote
If you can't find anything better, I'll try to rearrange my "backup plan."
Then I can take some pictures.
Let me know.
Translated on 09-09-2026, 17:20.
roorback
Post30-11-2012, 10:37    Subject: Vacuum Pump Disassembly: What Next? Quote
Hello.
THANK YOU for the offer - that sounds too complicated. I'm likely to damage it either way - I recently threw away a defective one - and even with that one, "only" one of the membranes/valves was broken - although, since you can't get replacement parts (thanks, Pierburg), that's probably the end for any pump icon_sad.gif.
"Someone might just have a pump like that on their workbench right now - that would be great. It's quite interesting that no one has ever encountered this problem before - I can't find anything about it, even in the most diverse online forums."
If everything else fails, I'll have to disassemble my other car to get parts, but I really wouldn't want to do that.
Thank you all again for your help.
Translated on 09-09-2026, 17:21.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post30-11-2012, 11:49    Subject: Vacuum Pump Disassembly: What Next? Quote
Not all vacuum pumps are the same. There are countless versions and designs.
I assume you're talking about the vacuum pump in your 5-cylinder Volvo with a VW engine?
Then there's the infamous one, like in the T4, and it's a well-known problem area.
http://www.t4-wiki.de/wiki/Vakuumpumpe
Since these seals at the top tend to leak and draw in oil over time, which gradually impairs their function, I would recommend replacing them at the same time. This will give you some peace of mind for a while.
A Pierburg part from VW costs around 260 euros, or you can find them for around 200 euros on online marketplaces, and aftermarket versions are available from around 70 euros.
This pump is a safety-critical component, so I wouldn't try to fix it myself; I would just replace it.
Translated on 09-09-2026, 17:23.
roorback
Post30-11-2012, 11:59    Subject: Vacuum Pump Disassembly: What Next? Quote
Hello.
Yes, exactly, it's about the pump.
I don't need a new pump, the one I have works perfectly fine!
BUT - it seems I have a test device. If I'm lucky, I'll receive it this afternoon, and then I can start documenting it.
If I do that, I'll let you know with a photo – someone might need it someday.
Thank you.
best regards, uwe
Translated on 09-09-2026, 17:25.
Tagessuppe
Post30-11-2012, 12:40    Subject: Vacuum Pump Disassembly: What Next? Quote
Perhaps this will help?
http://www.lt1-forum.de/dokuwiki/doku.php?id=start:reparaturtips:vacuumpumpe
Be careful with the lower seal as well.
It has to fit perfectly to be 100% airtight, and of course, it's not available as a replacement part.
"Best regards."
Translated on 09-09-2026, 17:26.
roorback
Post30-11-2012, 12:58    Subject: Vacuum Pump Disassembly: What Next? Quote
I'll take a look at that right away - THANK YOU.
roorback
Post03-12-2012, 8:54    Subject: Vacuum Pump Disassembly: What Next? Quote
Hello.
I was able to disassemble a pump over the weekend (not a Pierburg, but with a similar design) - here's the breakdown (in case anyone needs it).
Photo #1 - first, the sealing ring.
Photo #2 - the valve (direction as shown in the photo).
Photo #3 - with poetry.
Photo #4 - Complete.
 Tandempumpe komplett
 File size:  1.82 MB
 Viewed:  5383 times
 Tandempumpe mit Dichtung
 File size:  1.54 MB
 Viewed:  8298 times
 Tandempumpe Dichtring
 File size:  1.48 MB
 Viewed:  4394 times
 Tandempumpe Ventil
 File size:  1.58 MB
 Viewed:  4964 times
Translated on 09-09-2026, 17:27.
engl
Tagessuppe likes this.
Post10-12-2012, 18:30    Subject: Vacuum Pump Disassembly: What Next? Quote
It has nothing to do with the question, but:
I've also dealt with that pump issue several times before.
I would recommend buying a new one from the same manufacturer as an accessory right away.
You can finally put that to rest.
All the pumps I've disassembled have experienced the same problems again after just a few thousand kilometers.
Translated on 09-09-2026, 17:28.
roorback
Post11-12-2012, 10:06    Subject: Vacuum Pump Disassembly: What Next? Quote
Hello.
Yes, I am quite aware of that. I also once bought a new pump (around €250 at the time), and it started failing again after 20,000 km.
Basically, for me, it's just an acoustic issue that I tried to address during the engine rebuild. Right now, it's quiet, but if it starts again, I don't really care. I'm not worried about the pump, the camshaft, or the braking performance. If the vacuum pump is defective, you'll notice it. With my defective pump, the brake assist wasn't available for a while after starting the engine, which was very unpleasant. The problem was almost certainly a membrane, a cheap part that's hard to find.
Ultimately, I examined the pump from the inside, the cam, and the lifter - that should last for the next hundred thousand icon_wink.gif.
Translated on 09-09-2026, 17:29.
engl
Post11-12-2012, 13:35    Subject: Vacuum Pump Disassembly: What Next? Quote
Was the pump an original Pierburg part?
I once bought some cheap tires for a test on my T4; some of them actually showed a decrease in performance after only 20 kilometers!
It's dangerous what kind of junk you can find there.
Translated on 09-09-2026, 17:31.
roorback
Post11-12-2012, 13:38    Subject: Vacuum Pump Disassembly: What Next? Quote
Yes, it was original and cost around €250. I'm still driving it today - it probably has about 100,000 km on it now. It occasionally makes a rattling noise, but not as bad as the previous one. As I said, in my opinion, it's just an acoustic problem that you apparently can never completely get rid of.
No new posts Document Transporter 7D, vacuum pump making noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbo Failure: What to Do?:-(( Diesel Engine Technology
No new posts Vacuum Pump Troubleshooting: Hammering Noise? Diesel Engine Technology
No new posts Vacuum Pump 1Z Disassembly Guide Diesel Engine Technology
No new posts Audi 80 1Z Vacuum Pump Upload
