Triangle nut f. VP37 turnout frame
vwSchrauber
Post10-12-2012, 12:21    Subject: Triangle nut f. VP37 turnout frame Quote
I posted the Bosch part number for this specific nut in this forum a long time ago (around 2009?), but unfortunately, I can't find the thread anymore.
I once had a triangular file from Bosch, but unfortunately, it has already been stolen from my toolbox icon_evil.gif.
Does anyone know the Bosch part number?
Post10-12-2012, 13:54    Subject: Triangle nut f. VP37 turnout frame Quote
Bosch 0986612605?
I am sorry, but I cannot access external websites or specific files online. Therefore, I am unable to translate the text from the provided URL.
or
I am sorry, but I am unable to access external websites, including the one you provided. Therefore, I cannot translate the text from the given URL.
tdi-erwin
Post10-12-2012, 13:56    Subject: Triangle nut f. VP37 turnout frame Quote
Hello!
I used a Dremel tool to remove the triangular section from a 24-sided nut, following these instructions:
I am sorry, but I am unable to access external websites, including the one you provided. Therefore, I cannot translate the text from the German website into English.
Or, during my search, I found the following source:
Unfortunately, I cannot access external websites, including the one you provided from dieselkontor.de. Therefore, I am unable to translate the text from that page.
I've already replaced this gasket twice, once with an MKB AHU gasket, and it's been leak-free for 2 years!
1* Myocardial bridging, acute heart failure, 1 month ago.
Wishing you all the best.
tdi-erwin
vwSchrauber
Post10-12-2012, 18:19    Subject: Triangle nut f. VP37 turnout frame Quote
Thank you very much icon_biggrin.gif.
roorback
Karma: +1 / -2   Thank you, like it!
Post11-12-2012, 10:08    Subject: Triangle nut f. VP37 turnout frame Quote
Hey.
While not the most elegant or precise method, my approach (see attachment) involves using a Dremel.
Should it be replaced with a "standard" one?
 File size:  61.94 KB
 Viewed:  6464 times
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post11-12-2012, 10:49    Subject: Triangle nut f. VP37 turnout frame Quote
It also works with a good, sharp wire-cutting pliers.
To my uttermost dismay, I have even tried it with a hammer and chisel icon_biggrin.gif.
vwSchrauber
Post11-12-2012, 13:39    Subject: Triangle nut f. VP37 turnout frame Quote
If necessary, I can also do it with an 8mm Allen key that I hit with a hammer. However, such repair and correction methods do not look very professional to the customer icon_wink.gif.
alevuz
Karma: +32 / -0   Thank you, like it!
Post11-12-2012, 21:22    Subject: Triangle nut f. VP37 turnout frame Quote
Hello, and good evening.
Okay, here's a really silly question:
Is anyone going to Dieselkontor? "Do they only supply to companies?"
SG
Alevuz.
Touareg V10 TDI (AYH)
vwSchrauber
Post12-12-2012, 14:33    Subject: Triangle nut f. VP37 turnout frame Quote
alevuz
Post14-12-2012, 11:33    Subject: Triangle nut f. VP37 turnout frame Quote
I already understand that they only supply businesses.
I was just thinking/hoping that they might also deliver to users registered here, perhaps with a special arrangement.
SG
Alevuz.
vwSchrauber
Post17-12-2012, 14:42    Subject: Triangle nut f. VP37 turnout frame Quote
For your own vehicle, a slightly oversized 8mm hex key will also work. However, if you're doing this for customers, I would definitely recommend registering a business. It costs very little and makes many things easier or brings many things into a legal framework icon_wink.gif.
alevuz
roorback likes this.
Post18-12-2012, 15:48    Subject: Triangle nut f. VP37 turnout frame Quote
No way, I definitely won't do anything for others! My two boxes are enough for me!
As you can probably tell from my previous messages, I need a lot of specialized parts and tools, even for relatively minor tasks, especially when it comes to my V10 engine.
Unfortunately, there's not much room for improvisation.
The good thing about Dieselkontor was that they could supply everything, so it wasn't necessary to order from four different suppliers.
That's why I'm asking!
"Still, THANK YOU for the information..."
SG
ALevuz
klahaui
Avatar-klahaui
Post18-12-2012, 22:18    Subject: Triangle nut f. VP37 turnout frame Quote
Just go to a reputable independent workshop and have them order it for you.
I've been doing that for years whenever I encounter this problem.
"I'll also lend them things sometimes if they don't have them, and I get everything I need in return."
No new posts Quantity setting device and control path generator: Function Technical Articles
No new posts Disassembling the metering unit of a VP37 Troubleshooting & Guides
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts Adjustment aid for the quantity setting device on the VP37 Diesel Engine Technology
No new posts Engine Control Unit VP37 for VW T4 AJT-ACV - Data from VA... On-Board Diagnostics (OBD)
No new posts VP37 ESP: Cleaned Powder Meter According to Instructions. Diesel Engine Technology
No new posts Faulty Metering Valve? Get it Fixed! Diesel Engine Technology
