Intermittent error code P0234 on a Passat 3C 2.0 TDI
elyias1
Post24-12-2012, 16:38    Subject: Intermittent error code P0234 on a Passat 3C 2.0 TDI Quote
The error mentioned above appears sporadically, and I have not yet been able to reproduce it.
Can the error be narrowed down using the log file?
Jens
Log-NVP-EJ505-WVWZZZ3CZ6P023613-221780km.txt
 Autoscan 22.12.12
Autoscan 22.12.12
 File name:  Log-NVP-EJ505-WVWZZZ3CZ6P023613-221780km.txt
 File size:  13.42 KB
 Downloaded:  1305 times
LOG-01-001-011-015.CSV
 Probefahrt nach Fehlermeldung, hier nicht aufgetreten!
 File name:  LOG-01-001-011-015.CSV
 File size:  31.12 KB
 Downloaded:  563 times
Passat 3C 2.0 TDI BMP 6 Gang Schalter
Fabia 2.0
Pontiac Transsport 2.3 Schalter
"Am Ende wird alles gut. Wenn es nicht gut ist, dann ist es nicht das Ende..." Oskar Wilde
Translated on 13-07-2026, 3:34.
Post24-12-2012, 16:50    Subject: Intermittent error code P0234 on a Passat 3C 2.0 TDI Quote
If the engine control unit is in its original state, the variable geometry turbocharger (VTG) adjustment may be stiff or difficult, the vacuum actuator may be stuck, the vacuum system may not be properly vented, or there may be a short circuit at the VTG.
Translated on 13-07-2026, 3:35.
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt Replacement Problems: AGP, AGR, AHF, ALH &... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF removal for Passat 3C with BMP engine Troubleshooting & Guides
No new posts DPF Error: Volkswagen Golf 6 2.0 TDI Fix Diesel Engine Technology
No new posts N75 Valve Not Activating on VW Passat 2.0 TDI Diesel Engine Technology
No new posts Low boost pressure below 2500 RPM, Passat 2.0 TDI BMP Diesel Engine Technology
No new posts Passat 2.0 TDI: Driveshaft/Joint Part Numbers Explained Transmission, Chassis, Body & Interior
