Audi Turbochargers: Differences Explained
@udi
Post02-04-2013, 22:19    Subject: Audi Turbochargers: Differences Explained Quote
Hello.
I had to replace the turbocharger on my 2.5 TDI.
The new charger has the same part number, but a different letter at the end.
Now, sometimes the engine revs up very quickly, and other times it revs up to 4,000 RPM and then seems to hit a limiter.
Question: Could the difference between the chargers possibly be due to the vacuum sensor?
Can I take the vacuum sensor from the old loader?
Thank you in advance.
Jörg.
Translated on 22-09-2026, 16:58.
Post02-04-2013, 22:48    Subject: Audi Turbocharger: Differences Explained Quote
@udi wrote:
The new loader has the same part number, but a different trailing letter.
Is the other ending letter just an extra "X" (for exchange part) at the end, or is it actually a different part number? Please provide both here.
Generally, with VW/Audi, the complete part number, including the trailing letters, is crucial. It's possible that the letter at the end only indicates the revision (e.g., a larger letter might signify a newer version), but there are also many parts that are completely different (e.g., from a different supplier, or for a completely different application).
In the first case, it will probably work with a different letter as well, but in the latter case, it is sometimes completely incompatible.
Therefore, here are some more details:
a) Which part numbers?
b) New part or replacement part?
c) Source?
Greetings.
Guste.
Translated on 22-09-2026, 17:00.
Post03-04-2013, 7:52    Subject: Audi Turbochargers: Differences Explained Quote
And don't replace the vacuum tubes... that won't make it any better. First, try to narrow down the source of the problem.
Translated on 22-09-2026, 17:01.
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Rear brake calipers, difference? Audi A3 8L, year of manu... Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Difference Injection Nozzle T4 151HP / Audi AEL 140HP Diesel Engine Technology
No new posts Spark plug difference Audi 3.0 TDI 059 963 319E vs. J Diesel Engine Technology
No new posts Turbocharger Differences: Same Part Number? Diesel Engine Technology
