Golf 6 BiFuel: Gas ECU Diagnostics
Post29-04-2013, 12:05    Subject: Golf 6 BiFuel: Gas ECU Diagnostics Quote
...It's a Golf 6 Bifuel 1.6 with an original (factory-installed) gas system from...
Landirenzo.
As far as I know, this is located between the engine control unit and the fuel injection system.
The device is switched on. The VW designation is J659.
The gas steering control unit is not included in the Autoscan; how can I read its fault memory? I am using the MicroCAN, which only supports CAN.
Speculation: The Landi Renzo control unit is directly connected to the diagnostic socket via a K-line. Does anyone know if it can be accessed using standard VAG protocols, or if special software from Landi Renzo is required?
Translated on 12-08-2026, 3:37.
Post29-04-2013, 12:25    Subject: Golf 6 BiFuel: Gas ECU Diagnostics Quote
Does anyone know if it can be accessed using the standard VAG protocols, or is special software from Ladrirenzo required?
Not really. For example, with Irmscher (Opel), I know that these original equipment manufacturer (OEM) engine control units (ECUs) are supposedly not compatible with Landisoftware (source: Gasfritze), or can only be programmed/read by Opel.
Perhaps it's best to inquire directly with Landi.
http://www.landi.it/layout.jsp?idz=20026&idtp=151&lang=4#
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
Translated on 12-08-2026, 3:39.
Post29-04-2013, 17:57    Subject: Golf 6 BiFuel: Gas ECU Diagnosis & Repair Quote
dieselschrauber wrote:
... Does anyone know if it can be accessed using standard VAG protocols, or is specific software from Landi Renzo required?
"VAG software is not working... Special software is required."
Translated on 12-08-2026, 3:40.
Post29-04-2013, 18:02    Subject: Golf 6 BiFuel: Gas ECU Diagnostics Quote
The VAG software is not working... Special software is required.
You mean the software from Landi Renzo, or something specific for VW in conjunction with Landi-Renzo?
Post29-04-2013, 20:27    Subject: Golf 6 BiFuel: Gas ECU Diagnostics Quote
Autoservice wrote:
You mean the software from Landi Renzo?
No.
... or something very specific for VW in connection with Landi - Renzo?
Yes... Unfortunately icon_cry.gif.
Translated on 12-08-2026, 3:41.
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Eberspächer Heater Diagnostics: Troubleshooting Guide Troubleshooting & Guides
No new posts Webasto Heater Diagnosis: Retrofit Systems Troubleshooting & Guides
No new posts Golf IV/Audi A4 Diagnostic Interface On-Board Diagnostics (OBD)
No new posts Golf 4 TDI: Read Oil Temperature via Diagnostics On-Board Diagnostics (OBD)
No new posts Nozzle Heater Check: Golf 4 Diagnostics On-Board Diagnostics (OBD)
No new posts OBD2 Diagnostics for Non-Diagnostic CAN Bus On-Board Diagnostics (OBD)
