VAG-Com: Group 000 Not Working - Troubleshooting
alca
Post02-09-2003, 19:10    Subject: VAG-Com: Group 000 Not Working - Troubleshooting Quote
Hello professionals.
I could use a little tip.
I borrowed a VAG-Com 303 and I wanted to use the TDI-Graph, but I need to access group 000, but I can't. I get a warning message that it starts at group 001 and upwards.
Does anyone have any advice?
Okay, so I also tried version 2.28, and I was able to access group 000. However, when I go to the default values, I don't see a button to select the TDI graph.
Advice??
PS: I haven't found a better forum yet, and I'm still a beginner in this area, but thanks to your database, I've already been able to identify 2 issues with my car!
KEEP GOING LIKE THAT...........................
Translated on 28-08-2026, 5:13.
Michael II
Post02-09-2003, 22:01    Subject: VAG-Com: Group 000 Not Working - Troubleshooting Quote
If you had done some research, you would know that only the full version of VAG-Com...
indicates group 0.
Please always search first when you have questions like this.
Tschüss
Michael II
Translated on 28-08-2026, 5:15.
alca
Post03-09-2003, 8:35    Subject: VAG-Com: Group 000 Not Working - Troubleshooting Quote
hi
'Well, I already knew that from the full version, which I actually borrowed.'
but it still doesn't work!!
Even in version 2.28 (full version), the '000' group functions, but there is no button for the TDI Graph.
Michael II
Post03-09-2003, 9:00    Subject: VAG-Com: Group 000 Not Working - Troubleshooting Quote
Then, if I were you, I would contact the developer, Ross-Tech.
They are happy to provide information about the full versions.
Tschüss
Michael II
Translated on 28-08-2026, 5:16.
Gremlin
Post03-09-2003, 9:23    Subject: VAG-Com: Group 000 Not Working - Troubleshooting Quote
and even in version 2.28 (full version), the '000' group works, but there is no button with the 'TDI Graph' function there.
a little http://www.cheesebuerger.de/smilies/boese/41.gif would definitely be appropriate!
Then you would at least know that the TDI graph is only available from version 303.1 onwards.
CU Gremlin.
No new posts 4Motion keine Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Allroad Luftfahrwerk - keine Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J AC Repair: Troubleshooting Guide (99) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Nachrüstung GRA - keine Funktion On-Board Diagnostics (OBD)
No new posts Light/bell - no function Transmission, Chassis, Body & Interior
No new posts VW Auxiliary Heater with Standby Heater - Not Functioning Transmission, Chassis, Body & Interior
No new posts Audi A3 AC Not Working: 8P BKD Repair Guide Transmission, Chassis, Body & Interior
