1Z Passat Engine: Power Loss & Excessive Smoke
tmark
Post02-09-2003, 19:17    Subject: 1Z Passat Engine: Power Loss & Excessive Smoke Quote
Hello.
I'm having problems with a 90hp TDI engine (model 1Z) in a Passat 35P (mileage: 220,000 km).
"Up to 100 km/h, there are no performance issues other than a bit more smoke than usual (in 2nd or 3rd gear)."
Above 100 km/h, almost no acceleration, a lot of smoke, and a maximum speed of 130-140 km/h.
The solenoid valve has already been replaced --> it's a little better, but still only reaches a maximum speed of 130-140 km/h, and there's a lot of smoke!
Consumption has also increased (approximately 1 liter per 100 kilometers).
Can someone please help me?
Thank you.
Markus.
Translated on 10-09-2026, 6:36.
WarLord
Post02-09-2003, 19:49    Subject: 1Z Passat Engine: Power Loss & Excessive Smoke Quote
The pipes to and from the turbo are fine, as is the intercooler. Which injectors are being used? Are they still the original ones? One more question: What crankshaft bolt is installed? Is it still the old one with a strength rating of 8.8, or the one with a strength rating of 12.8?
Best regards, WarLord.
Translated on 10-09-2026, 6:38.
Michael II
Post02-09-2003, 22:03    Subject: 1Z Passat Engine: Power Loss & Excessive Smoke Quote
PLEASE use the search function. Then, perform the tests described there.
If any uncertainties or problems arise, please feel free to ask here.
(unless it has already been discussed extensively in the forum).
Tschüss
Michael II
tmark
Post04-09-2003, 20:57    Subject: 1Z Passat Engine: Power Loss & Excessive Smoke Quote
Hello.
The problem has been resolved. A boost pressure hose was replaced.
Thank you again!
Markus.
Translated on 10-09-2026, 6:39.
No new posts DPF removal for Passat 3C with BMP engine Troubleshooting & Guides
No new posts AJM Motor - Motor klappert, Leistungsmangel, Schwarzrauch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.9 TDI rapid power loss, severe knocking Diesel Engine Technology
No new posts schlechter Start,starkes Leerlaufruckeln,Leistungsverlust Diesel Engine Technology
No new posts 96kW TDI PD in a Passat 3BG and strong acceleration (wet) Diesel Engine Technology
No new posts Audi A6 3/99 AFB: Occasional smoking after turbocharger r... Diesel Engine Technology
