DSG Problems Passat CC - Solved
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
inf
Post23-05-2013, 20:12    Subject: DSG Problems Passat CC - Solved Quote
Today, I performed a diagnostic scan on my vehicle and found errors in the DSG (dual-clutch transmission) and DCC (dynamic chassis control) systems. I cleared both errors, and a few days later, I scanned the car again. The DCC error didn't reappear, but the DSG error did. I'm taking the car to the dealer next week. Can the dealer do anything about the DSG error?
I'm generally happy with the DSG, so this is a bit surprising.
Best regards, Stefan.
Autoscan.txt
 File name:  Autoscan.txt
 File size:  14.7 KB
 Downloaded:  1964 times
Gruß, Stefan
Translated on 16-10-2026, 2:42.
Post23-05-2013, 20:27    Subject: DSG Problems Passat CC - Solved Quote
Is the oil level correct in the DSG (Dual Clutch Gearbox)?
Translated on 16-10-2026, 2:43.
inf
Post23-05-2013, 20:40    Subject: DSG Problems Passat CC - Solved Quote
Hello Rainer,
"I'll have it checked. Can I do that myself? I think it probably needs to be replaced anyway at 60,000 km."
Gruß, Stefan
Translated on 16-10-2026, 2:44.
Post23-05-2013, 21:48    Subject: DSG Problems Passat CC - Solved Quote
Look here: https://community.dieselschrauber.org/en/viewtopic.php?t=26396
If a change is already planned, I would go ahead and have it done.
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
inf
Post31-05-2013, 19:53    Subject: DSG Problems Passat CC - Solved Quote
The vehicle is now at the VW dealership. The diagnosis is a faulty mechatronic unit. This rules out an oil change as the cause of the problem. Now I'm waiting for the replacement part... I'm curious to see how long it will take!
Gruß, Stefan
Post31-05-2013, 22:14    Subject: DSG Problems Passat CC - Solved Quote
Thank you for the feedback! I was just about to ask about the mileage, but it says 47554 km in the log. icon_eek.gif
Translated on 16-10-2026, 2:45.
Post31-05-2013, 22:34    Subject: DSG Problems Passat CC - Solved Quote
but the log shows 47554 km.
icon_eek.gif:wink:
At least it's almost 48,000 km. And it's not the first one that hasn't made it past 50,000 km.
For that price, it's a real bargain at approximately 2000 EUR (excluding installation), compared to the entire transmission, which costs around 6000 EUR. icon_cry.gif
One should generally advise against buying used vehicles with DSG transmissions if there is no warranty - unfortunately. }
As far as I know, spare parts are practically unavailable.
Translated on 16-10-2026, 2:46.
inf
Post12-06-2013, 20:31    Subject: DSG Problems Passat CC - Solved Quote
The car is back, and thankfully, it was fixed a bit faster than expected. They replaced the DSG mechatronic with a new one, along with a new filter and oil. What can I say, it drives much better now! The DSG now downshifts occasionally and shifts very smoothly, almost without any interruption in power delivery. And the gear changes now work without any jerking in the transmission. So, I hope it stays this way!
Gruß, Stefan
Translated on 16-10-2026, 2:47.
Post12-06-2013, 21:09    Subject: DSG Problems Passat CC - Solved Quote
Okay, good luck and thank you for the feedback icon_wink.gif.
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wastegate actuator for turbocharger stuck. Solved Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LWR Error: Unrecoverable Memory Corruption (Solved) On-Board Diagnostics (OBD)
No new posts DSG P17BF Error: Skoda Octavia Hydraulic Protection Fix Transmission, Chassis, Body & Interior
No new posts EPB Passat 3C error On-Board Diagnostics (OBD)
No new posts VW Passat 1.9 TDI: Error Codes G70, G81, G62 Diesel Engine Technology
