Throttle Body Cleaning: T3 WBX (Solved)
New Topic 🔒 Locked 🔗 🖨 Dieselschrauber - Index » Gasoline Engine Technology
Post21-08-2013, 22:00    Subject: Throttle Body Cleaning: T3 WBX (Solved) Quote
How is the throttle valve mounted on the T3 (MJ 89) carburetor?
At first glance, I see a large clamp connecting the rubber hose to the air filter housing, and two Phillips-head screws on the air intake manifold, which is mounted on the engine.
The throttle cable coming from the front, and a vacuum-operated sensor that controls a second throttle valve (?), also need to be disconnected from their surroundings.
The bus has a problem where the idle speed gets stuck at 1200 rpm when it's warm. However, it's NOT the typical "cigarette" issue.
Because if it's warm and "stuck," you can push the DK just a millimeter further, and everything will fit.
You can do it from a standstill by lightly tapping the accelerator and letting it slip, then the DK will engage properly.
The plan is now to expand and clean the thing.
PDFs with instructions are welcome icon_smile.gif.
Sure, no problem. Here's the translation:
"Thank you in advance."
Translated on 13-09-2026, 2:55.
Post22-08-2013, 11:32    Subject: Throttle Body Cleaning: T3 WBX (Solved) Quote
It's actually self-explanatory.
Remove air filter.
Disconnect the air filter intake hose.
Disconnect the gas cable.
Remove the throttle body housing.
And don't swap anything around, and be sure to label any wires, cables, or connections.
Translated on 13-09-2026, 2:57.
Post22-08-2013, 20:34    Subject: Throttle Body Cleaning: T3 WBX (Solved) Quote
Perfectly explained car service icon_biggrin.gif, you don't need any instructions, it's very easy, and everything is very clear.
Post22-08-2013, 23:03    Subject: Throttle Body Cleaning: T3 WBX (Solved) Quote
You're right, it wasn't that bad.
The throttle body was disassembled (the butterfly valve was removed and its edges were polished) and then reassembled.
The idle speed is stable, both when cold and when warm.
Now I've discovered a crack in the exhaust icon_sad.gif.
 Drosselklappe SS Wasserboxer
 File size:  68.64 KB
 Viewed:  9707 times
Translated on 13-09-2026, 2:58.
Post26-08-2013, 9:47    Subject: Throttle Body Cleaning: T3 WBX (Solved) Quote
You must not install the throttle cable too tightly!!!
Otherwise, the engine will start revving up again when it gets warm.
Somehow, the vehicle seems to lengthen during operation (the Concorde did the same, and a T3 almost reaches its speed icon_smile.gif).
Once the engine is fully warmed up, the throttle cable suddenly becomes too short, resulting in a low idle speed of 1500 rpm.
Translated on 13-09-2026, 2:59.
Post26-08-2013, 17:22    Subject: Throttle Body Cleaning: T3 WBX (Solved) Quote
The vehicle seems to elongate during operation
Reduce towing load icon_wink.gif.
Avatar-Jan6K
Post26-08-2013, 20:37    Subject: Throttle Body Cleaning: T3 WBX (Solved) Quote
With a front-wheel drive vehicle, I would understand that, but in a T3, the brutal power of the engine seems to compress the car rather than propel it forward. icon_smile.gif
Jan.
1Z5 CFHF / AHB H4D
Translated on 13-09-2026, 3:00.
Post26-08-2013, 20:39    Subject: Throttle Body Cleaning: T3 WBX (Solved) Quote
It's silly when you only read diagonally. icon_lol.gif You're right, I was thinking about the T4.
Post26-08-2013, 23:02    Subject: Throttle Body Cleaning: T3 WBX (Solved) Quote
Is the throttle cable and accelerator pedal easy to operate? It's not uncommon for them to become stiff or difficult to move!
Translated on 13-09-2026, 3:01.
Post27-08-2013, 10:02    Subject: Throttle Body Cleaning: T3 WBX (Solved) Quote
Sure, here's the translation:
"Nene,"
Everything is okay now.
Everything is working smoothly.
During assembly, I had pulled the rod tightly towards the back of the flap and then screwed it in. So, it was already under some tension.
Apparently, the thermal expansion of the gearbox components (specifically, the throttle valve moving away from its pivot point on the gearbox housing) was enough to cause the now extremely light throttle valve to open slightly.
And that really revs up the supercharger.
That's why he specifically designed that cross-section bolt on the DK, to reduce the cross-sectional area when the opening is small.
Otherwise, he could probably only use "Kickdown" icon_smile.gif.
Other WBX models apparently also had a third spring (in addition to the two directly attached to the distributor cap) that pre-tensioned the throttle lever on the air distribution manifold.
"It's no longer available, and I don't think it was ever included in "our" SS version."
However, all the air ducts have a support at the rear, upper end of the seam.
Hmm, this SS has the pen.
[dead image link]
Translated on 13-09-2026, 3:02.
Post10-09-2013, 12:12    Subject: Throttle Body Cleaning: T3 WBX (Solved) Quote
But none of that has anything to do with cleaning a throttle body anymore.
For those interested in the fuel consumption of such a vehicle:
Translated on 13-09-2026, 3:04.
No new posts Throttle Body V157 Fault, P3103 Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Removing and cleaning a diesel particulate filter (DPF) Troubleshooting & Guides
No new posts Wastegate actuator for turbocharger stuck. Solved Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A5 throttle body Diesel Engine Technology
No new posts Throttle valve - error Diesel Engine Technology
No new posts Polo 6N Throttle Body Initial Adjustment Gasoline Engine Technology
No new posts Adapt throttle valve Lupo 16V Gasoline Engine Technology
