Final Report & Thank You | Posts 32+
Go to page: Previous  1, 2, 3
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
Karma: +590 / -0   Thank you, like it!
Post04-09-2013, 20:00    Subject: Final Report & Thank You Quote
Hello!
The vehicle owner has now decided to purchase the correct pump that was offered by company E**.
Previously, an agreement was made with the seller regarding a right of return in case of malfunction.
The pump is now installed, and the car is working perfectly again.
I would like to express my sincere gratitude to everyone involved for their hard work and support!
Translated on 11-08-2026, 10:54.
Post04-09-2013, 21:51    Subject: Final Report & Thank You Quote
Okay, then thank you for the feedback icon_wink.gif.
Translated on 11-08-2026, 10:55.
No new posts Wastegate actuator for turbocharger stuck. Solved Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Oil in timing chain drive - MKB ABS (Solved) Gasoline Engine Technology
No new posts Solved 90% BNS (BCM) T5.2 MDI and FSE coding? On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Multifunction steering wheel (Solved) Electrical Systems, Vehicle Electronics, Multimedia
No new posts Vacuum in VTG Can: Troubleshooting & Solutions Diesel Engine Technology
