T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
27-08-2013, 22:53 Subject: WBX SS Consumption: Data & Analysis |
EDIT: Continuation of: https://community.dieselschrauber.org/en/viewtopic.php?p=211951#211951
Ahhh, beautiful engine  .
That was the first engine; you could hardly feel any vibration until it reached its maximum speed.
If it weren't for this  , which is at 16 liters per 100 km  . NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Translated on 24-08-2026, 19:48.
Profile PM Email Garage |
03-09-2013, 12:06 Subject: WBX SS Consumption: Data & Analysis |
The speedometer works, but the odometer doesn't.
Therefore, the consumption is theoretically infinite.
Now, first of all, the front shock absorbers need to be replaced, according to the TÜV  , until October 2nd. Transparency, Teamwork
Translated on 24-08-2026, 19:49.
Profile PM Garage |
08-09-2013, 14:54 Subject: WBX SS Consumption: Data & Analysis |
Maximum speedometer reading: 105 km/h. Trip from the Palatinate region to Cologne and back: fuel consumption of 9.79 liters per 100 kilometers.
Not really low, but less than 16 liters per 100 kilometers.
(With a Passat (at 105 km/h), it would have only cost half as much... *swallows*).
Okay, please provide the German text you would like me to translate into English. I will only provide the translation. Transparency, Teamwork
Translated on 24-08-2026, 19:50.
Profile PM Garage |
08-09-2013, 21:20 Subject: WBX SS Consumption: Data & Analysis |
dieselmartin wrote: | First, the front shock absorbers need to be replaced, according to the TÜV ... until October 2nd. | However, regarding the odometer, it should also indicate something.  MfG. Michael
Translated on 24-08-2026, 19:52.
Profile PM Garage |
08-09-2013, 22:05 Subject: WBX SS Consumption: Data & Analysis |
dieselmartin wrote: | .
Maximum speedometer reading: 105 km/h. Trip from the Palatinate region to Cologne and back: 9.79 liters per 100 kilometers.
m; |
Well, I was 19 years old and a terrible driver  . Also, driving slowly doesn't mean using less than 13.5 liters per comparison to my first car, a Fiat Panda from 1979 with a laughable 34 horsepower; its constant top speed depended on the wind and could reach 100-160 km/h, but never more than 7 liters  .
After that, my Mercedes "Roslaube" (a nickname), a 1977 W123 250 carburetor gasoline engine with automatic transmission, also doesn't go below 13 liters  . NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Translated on 24-08-2026, 19:53.
matthiasTDI96 Profi-Schrauber
09-09-2013, 7:32 Subject: WBX SS Consumption: Data & Analysis |
Does a mileage counter have to function for the TÜV (German technical inspection)? Isn't it enough that the speedometer displays kilometers per hour? How is this checked?
Translated on 24-08-2026, 19:55.
09-09-2013, 9:34 Subject: WBX SS Consumption: Data & Analysis |
"Hi,"
"The presence of an odometer is mandatory. However, I don't think anyone checks whether it actually works, as long as there are numbers displayed. It would only become noticeable if the last report shows exactly the same mileage reading as what is currently displayed."
January. 1Z5 CFHF  / AHB H4D
Translated on 24-08-2026, 19:56.
09-09-2013, 19:43 Subject: WBX SS Consumption: Data & Analysis |
Jan6K wrote: | Hi,
"The presence of an odometer is mandatory. However, I don't think anyone checks if it actually works, as long as there are numbers displayed. It would only become noticeable if the last report showed exactly the same mileage as what is currently displayed."
Jan | .
I see it the same way! If it's exactly the same examiner, then he might notice it. But it's not a big deal.
Most often, in the T3 speedometer, the gear shaft has slipped out of its housing, or the plastic pinion gear has detached from the metal. It's usually quite easy to repair. The same issue can occur with many other mechanical speedometers. NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Translated on 24-08-2026, 19:57.
