aktuelle (magnet. CR) TDI ohne Drallklappen | Posts 16+
Go to page: Previous  1, 2
sepp.bayern
Post18-09-2013, 1:36    Subject: Quote
Hello Jan,
I have the same car as you, although we don't have a balance shaft module anymore.
but what about the oil pump that is driven by a timing belt in an oil bath?
will?
If it breaks, it's time to go home.
According to the self-study materials, the belt does not need to be replaced.
I'm already anxious about the day when the oil pressure warning light comes on.
Best regards, Christian.
Translated on 27-09-2026, 22:24.
Jan6K
Avatar-Jan6K
Post18-09-2013, 8:57    Subject: Quote
I wouldn't call that "the end of the workday"... unlike a broken timing belt, which drives the camshafts, nothing immediately breaks in this case. I hope it's enough to simply turn off the engine immediately when the oil pressure warning light comes on. It definitely won't run without any oil.
It wouldn't be ideal for the turbo if that happened while driving at full speed on the highway.
Jan.
1Z5 CFHF / AHB H4D
Translated on 27-09-2026, 22:25.
Post18-09-2013, 19:12    Subject: Quote
will?
If it breaks, it's time to stop.
We will have to get used to that. Other manufacturers are already integrating the water pump into the oil-cooled timing chain system.
It's simply a matter of "stinginess," not a question of technical feasibility.
As far as I know, all timing rollers for oil pumps at VAG come from Dayco, so that's why... icon_wink.gif
Aunt Edit: http://www.daycoaftermarket.com/DE/DE/press-folder.php
Translated on 27-09-2026, 22:27.
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Brake Fluid MIL: No Function Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A6 4B, valid until 03/2001, central locking, sin... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BMW X3 swirl flaps Transmission, Chassis, Body & Interior
No new posts BMR intake manifold swirl flaps repeatedly leak Diesel Engine Technology
No new posts Removing Swirl Valves: Experience and Tips Diesel Engine Technology
No new posts BMW 123d Swirl Flaps: Problems & Solutions On-Board Diagnostics (OBD)
