Welches Fahrwerk/Federn für einen A6 Avant 2,5 TDI??
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Frankenchris
Post10-09-2003, 17:52    Subject: Welches Fahrwerk/Federn für einen A6 Avant 2,5 TDI?? Quote
Hello everyone,
I recently installed 18-inch alloy wheels with dimensions 8J18 ET 35 and tires 235/40 ZR18-91 on my A6 (manufactured in 1999). The permissible axle load at the front is 1185 kg and at the rear is 1100 kg. This already looks quite good, but I would now like to lower it a bit more. Please note the following criteria:
1. I have combined a pneumatic suspension with shock absorbers and a normal spring on the rear axle. (After installing the suspension, how can I set the basic position of the pneumatic suspension to the new vehicle height?)
2. I have a caravan (ZgG 1300 kg). How low can I go without having problems when pulling my caravan?
3. Good balance of comfort and hardness.
4. I definitely don't want to engage in any kind of gambling or similar activities.
5. I hear from many people that when they buy a 30mm suspension, it actually lowers the car by 50mm?? What ACTUAL lowering would you recommend for me?
Best regards
Chris
http://frankenchris.netfirms.com/vorderrad.jpg
http://frankenchris.netfirms.com/komplett.jpg
http://frankenchris.netfirms.com/rad.jpg
No new posts Calix Motor Heater Installation Guide Troubleshooting & Guides
No new posts Which suspension? Transmission, Chassis, Body & Interior
No new posts Clunking Noise Suspension - Audi 80 Avant B4 1Z Transmission, Chassis, Body & Interior
No new posts LL Service: What event can trigger it? Diesel Engine Technology
No new posts GTI springs Transmission, Chassis, Body & Interior
