Label File Redirection Failed
Schraeuberling
Post28-10-2013, 22:44    Subject: Label File Redirection Failed Quote
Hello community,
I still have some questions about label files and their redirects.
I am using version 11.11.6, which is the latest version.
For example, during an Autoscan, the engine control unit displays "Redirection failed!".
It is a control unit with the part number "03G 906 016 LP".
In the label file "03-01.lbl", there is a REDIRECT to the label file "03G-906-016-BRB.LBL", which, however, does not exist.
Am I wrong to assume that redirects only exist if the target label file fundamentally also exists, and in my case, it's simply not on the hard drive for some reason?
Is there a label file named "03G-906-016-BRB.LBL"?
If possible, I would like to have them.
Thank you for your help.
Gerhard.
Das Reh springt hoch, das Reh springt weit, warum auch nicht, es hat ja Zeit.
Translated on 25-08-2026, 11:04.
Post29-10-2013, 10:40    Subject: Label File Redirection Failed Quote
I am using version 11.11.6, which is the current version.
No. The latest version is always available for download in the customer account and is version 12.12.0.
Am I wrong to assume that redirects only exist if the target label file fundamentally also exists?
"Correct. Please send such messages directly to the email address listed in the redirection labels (03-01.lbl)."
Translated on 25-08-2026, 11:06.
Schraeuberling
Post29-10-2013, 13:13    Subject: Label File Redirection Failed Quote
Hello Rainer,
Thank you for the quick response.
NOW I have installed the latest version, thank you for the information.
The email to Sebastian is being sent as well.
Thank you and best regards,
Gerhard.
Translated on 25-08-2026, 11:07.
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf V 1.4 Gasoline GRA retrofit failed Electrical Systems, Vehicle Electronics, Multimedia
No new posts Golf 4, year 2003 - KOBD2Check - Operation failed On-Board Diagnostics (OBD)
No new posts Label File: Create, Edit, and Print Labels On-Board Diagnostics (OBD)
No new posts Label file issues On-Board Diagnostics (OBD)
