Polo 9N3: Förderbeginn nach ZK- Wechsel prüfen? (Gelöst) | Posts 16+
Go to page: Previous  1, 2
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
Post20-11-2013, 20:52    Subject: Quote
Therefore, the rotation angle at a warm engine operating temperature is -2.3°.
Just to add to that, you can leave it as is. This makes the torque curve "slightly" more harmonious, and as the timing belt ages, it will naturally shift a bit later anyway. I deliberately set my AJM engine to -3°.
Translated on 21-09-2026, 21:07.
stolley
Karma: +38 / -1   Thank you, like it!
Post20-11-2013, 22:27    Subject: Quote
Autoservice wrote:
You can leave it like that, I would like to add. This makes the torque curve "slightly" more harmonious, and as the ZR ages, the whole thing will shift a bit more towards later timing anyway. I deliberately set my AJM to -3°.
Great, thanks for the information!
I'm going to leave it like that. Here's to the next 150,000 km! icon_razz.gif
By the way, the angle was -2.7° when the engine was cold.
Best regards and thanks to everyone!
Volker.
Translated on 21-09-2026, 21:08.
Post21-11-2013, 0:01    Subject: Quote
Okay, so the case can be closed and filed away icon_wink.gif.
Translated on 21-09-2026, 21:09.
No new posts Touran GRA not working after TCU replacement Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku MKB ABC, schlechter Motorstart nach MSG-Wechsel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wastegate actuator for turbocharger stuck. Solved Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Electric Window Regulator for Polo 6N2 (Solved) Transmission, Chassis, Body & Interior
No new posts ZR Seal Replacement: Performance Loss Troubleshooting On-Board Diagnostics (OBD)
No new posts Rotation Angle After Z-R Transformation Diesel Engine Technology
No new posts BMR unrund nach PPD Wechsel Diesel Engine Technology
