Audi A4 particulate filter after cleaning and with new engine
poppel
Karma: +1 / -2   Thank you, like it!
Post02-01-2014, 16:55    Subject: Audi A4 particulate filter after cleaning and with new engine Quote
Hello and happy new year.
The particulate filter in the Audi A4 engine (BPW) had been cleaned by a specialized company. During the installation, a major engine failure was also discovered. A used engine was then installed, along with the cleaned particulate filter. The technician set the ash mass value to "new filter" using a Bosch tester. Immediately after driving a few meters, an error message appeared. I then read the ash mass value using VCDS. It showed a value of 4, and the error message was "P0471 - 000, implausible signal from the exhaust gas pressure sensor (G450)." The sensor had already been replaced for safety. I cleared the error, re-initialized the sensor, and set the ash mass value to 8. Unfortunately, the cleaning protocol was no longer available. The error is no longer appearing, but the Audi is performing a particle filter regeneration every 30 kilometers. Need Help:-).
Best regards, Poppel.
Post02-01-2014, 17:45    Subject: Audi A4 particulate filter after cleaning and with new engine Quote
First, please provide the vehicle data and a complete error scan so we can identify the vehicle type and model. It depends on the specific details.
- Is it ensured that the filter is "truly" free of ash?
- Is the installed motor the same as the old motor, and is it hardware-wise identical? This includes.
also, for example, the PDs as well.
- Is everything properly wired and routed?
- What are the soot levels and pressure differences? /viewtopic.php?t=25715
Edit:
It would also be interesting to know the offset of the two differential pressure sensors when the ignition is on.
Also, the exhaust gas temperatures before and after the particulate filter.
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
Xoctron
Post02-01-2014, 18:03    Subject: Audi A4 particulate filter after cleaning and with new engine Quote
It would also be interesting to see the offset of the two differential pressure sensors when the ignition is turned on.
poppel
Post02-01-2014, 21:07    Subject: Audi A4 particulate filter after cleaning and with new engine Quote
Okay, here's the data from the error log that I saved earlier.
The engine should be identical to the original engine.
I can't verify whether the filter was truly clean, as the cleaning record is no longer available. "It should be in almost new condition."
I need to figure out the soot loading and pressure differences tomorrow.
Audi A4, year 2007, engine BPW, first diesel particulate filter, professionally cleaned.
VCDS
Windows-based VAG/VAS emulator.
Version: RKS 12.12.0
http://shop.dieselschrauber.de/
Dealer/Workshop name:
Company number: 000 00000
Self-diagnosis protocol.
Friday, December 27, 2013, 12:24:10:53149
Vehicle Identification Number: License Plate:
Mileage: 157889
Repair order:
Control unit part number: 03G 906 016 LQ HW: 03G 906 016 LQ
Component and/or version: R4 2.0L EDC G000CG 1717.
Encoding: 0000076
Company number: WSC 00011 888 181093
VCID: 7DFB8BA3243EF3F6FF5-8028
"1 error found:"
001137 - Exhaust gas pressure sensor 1 (G450)
P0471 - 000 - Implausible signal.
Freeze Frame:
Error status: 01110000
Error priority: 2
Error frequency: 1.
Counter for lost items: 255.
Time: 0.
Freeze Frame:
Speed: 0 RPM.
Speed: 0.0 km/h
(no unit): 96.90
(no unit): 35.70
Air mass: 5.69 g/s.
Temperature: 318.0°C
Temperature: 9.0°C
Readiness: 1 1 0 0 0
No new posts Motor dreht hoch nach Warmstart Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Q5 8RB DPF after cleaning, needs to be re-tuned. Diesel Engine Technology
No new posts [Poll] Erfolgsquote nach MSW-Reinigung bei VP-TDIs Diesel Engine Technology
No new posts Regelschieberspannung nach Reinigung verändert! Diesel Engine Technology
No new posts Starting difficulties/high fuel consumption; cleaned afte... Diesel Engine Technology
