Diesel Common Rail: Denso develops 1800 bar system
Post12-09-2003, 7:52    Subject: Diesel Common Rail: Denso develops 1800 bar system Quote
http://www.all4engineers.com/preview.php?alloc=1&lng=de&id=1833
Translated on 05-10-2026, 22:26.
Post12-09-2003, 8:15    Subject: Diesel Common Rail: Denso develops 1800 bar system Quote
What do they mean by "five-fold injection"?
5-hole nozzles or something like 4-port injectors plus the actual ????
...although the latter is probably nonsense icon_wink.gif.
P.S. Doesn't the AFN have 8-hole nozzles???
Post12-09-2003, 8:31    Subject: Diesel Common Rail: Denso develops 1800 bar system Quote
dieselmartin wrote:
What do they mean by "five-fold injection"???
Why would that be nonsense?
Bosch and Siemens VDO already offer their piezo common rail injectors with the option of seven pilot injection cycles (Alfa currently has five). Several small pilot injections reduce the noise level and can also reduce emissions. Unfortunately, this comes at the expense of power output.
Translated on 05-10-2026, 22:27.
Gremlin
Post12-09-2003, 10:41    Subject: Diesel Common Rail: Denso develops 1800 bar system Quote
The magnet injectors can deliver up to 5 injections per cycle, while the piezo injectors can deliver up to 7 injections per cycle.
This allows for a multi-point injection system, a separate main injection, and one or two post-injection events (for exhaust aftertreatment, also known as a diesel particulate filter).
But why is Denso now developing another 1800 bar common rail system with solenoid injectors...?
Bosch is launching its piezo injectors and is working on even more pressure (with pressure amplification within the injectors).
In addition, variable nozzles are under development that offer a changeable hole cross-section. Currently, this is achieved by having two rows of holes. One row consists of 'smaller' holes that provide good atomization at partial load, and a few 'larger' holes that can be opened additionally at high flow rates and pressures.
CU Gremlin.
Translated on 05-10-2026, 22:29.
diesel.gustav
Post13-09-2003, 22:16    Subject: Diesel Common Rail: Denso develops 1800 bar system Quote
Deleted upon request.
Translated on 05-10-2026, 22:30.
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code P2178 - Engine running too lean Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code P2177 - Lean condition system during idle Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI with Common Rail: Explained & Benefits Diesel Engine Technology
No new posts Common Rail vs. TDI: Which is Better? Diesel Engine Technology
No new posts Common Rail Injectors: LT 35 Refurbishment? Diesel Engine Technology
No new posts Common Rail Tool Set for Timing Belt Replacement Diesel Engine Technology
