Deus Violentia Schrauber
17-02-2014, 22:09 Subject: Piston Animation: ARL - Your Opinion Needed |
After a long absence, I have a question for you:
Attached you will find pictures of an ARL piston with approximately 170,000 km on it.
from an engine with significantly enlarged piston dome features, which is also evident from the piston itself.
What I see: Partial adhesion on the top surface, and slight scratches that are only visible upon close inspection.
In my opinion, the piston skirt coating is likely caused by an extremely high fuel injection rate.
with the oil film washed away. Overheating of the omega cavity (see the burn mark above the).
(Bolt holes) No cracks found!
The engine was still running, but it had a crack in the cylinder head and was completely replaced with an automatic transmission, which is why it was ultimately discarded.
The engine block, including the crankshaft mechanism, remains. The connecting rods and crankshaft are in perfect condition!
Now my question: Assuming the piston still meets the dimensional specifications, is it still scrap metal?
Can I reuse it with new piston rings? What do you think about that?
| Description: |
| File size: |
163.65 KB |
| Viewed: |
1596 times |
| Description: |
| File size: |
130.31 KB |
| Viewed: |
1578 times |
| Description: |
| File size: |
144.38 KB |
| Viewed: |
2023 times |
| Description: |
| File size: |
151.06 KB |
| Viewed: |
1820 times |
| Description: |
| File size: |
206.21 KB |
| Viewed: |
1957 times |
BKD GRF
AHF EBF
Translated on 11-10-2026, 14:10.
17-02-2014, 22:22 Subject: Piston Animation: ARL - Get Expert Opinion |
Deus Violentia wrote: | | ...can I reuse it with new piston rings? What do you think about that? | It depends on what it's for and for how long.
I'd say he's definitely done for, as far as any future prospects are concerned.
Translated on 11-10-2026, 14:12.
Profile PM Garage |
17-02-2014, 22:26 Subject: Piston Animation: ARL - Your Opinion Needed |
Well, I was already planning to use that sentence in the relevant performance level, but I have my doubts about whether that would be a good idea...
BKD GRF
AHF EBF
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
17-02-2014, 23:19 Subject: Piston Animation: ARL - Your Opinion Needed |
Quote: | | Well, I wanted to use the sentence in the relevant performance class, but I have my nagging doubts about whether that would be a good idea.... |
Practice makes perfect  .
Ich persönlich würde ihn ersetzen, weil der ET Aufwand in keinem Verhältnis zur evt. NaIt's a matter of personal preference.
If he or a replacement engine were to be operated in the same engine block again, I would check the block for flatness and, if necessary, have it resurfaced.
Translated on 11-10-2026, 14:13.
18-02-2014, 10:18 Subject: Piston Animation: ARL - Your Opinion Needed |
Thanks BM! In your opinion, which is more "critical"? The condition of the graphite coating, or the thermal overload that has already occurred on the material?
BKD GRF
AHF EBF
18-02-2014, 11:51 Subject: Piston Animation: ARL - Your Opinion Needed |
These grooves in the graphite coating often occur when the pistons are removed, due to deposits forming in the top of the cylinder above the first compression ring.
I would be more concerned about the thermal stresses that have already occurred.
Translated on 11-10-2026, 14:14.
Profile PM Garage |
18-02-2014, 12:02 Subject: Piston Animation: ARL - Your Opinion Needed |
Quote: | | I would be more concerned about the thermal stresses that have already occurred in that area. |
 Who knows when the first crack will appear there or in the recess, although the damage on the outer piston bottom looks more like a minor cavitation damage. However, this does not change the fact that the piston needs to be replaced for the reasons mentioned above.
Translated on 11-10-2026, 14:15.
20-02-2014, 11:43 Subject: Piston Animation: ARL - Your Opinion Needed |
I would like to thank you very much for your assessment of the situation  .
BKD GRF
AHF EBF
