Einspritzmenge für Heißstart | Posts 16+
Go to page: Previous  1, 2
Post11-08-2010, 7:26    Subject: Quote
Rainer K. wrote:
I said it's not about the ASZ.
However, that apparently doesn't apply to all ASZs.
For example, with the 019LA, I can use the code 12233 to change the EGR setting to its maximum limit (channel 3).
Translated on 18-08-2026, 19:10.
yanliz
2004 Audi A4 Avant
Post11-08-2010, 9:33    Subject: Quote
I also experienced the problem with the 12233 login. When a friend tried it using the VAS tester at the Audi workshop, it worked. After that, it started working again on my laptop as well. I don't know why.
I also wrote that in my thread, but that thread was deleted for no reason.
Audi A4 Avant 1.9TDI MJ2004
MKB: AVF, GKB: HCF 6-Gang
Translated on 18-08-2026, 19:11.
major
Registered VCDS User
Post17-12-2013, 7:01    Subject: Fuel Injection for Hot Start Quote
My Touran 2.0 (engine code BMN) is also currently experiencing warm start problems. I've tried adjusting the fuel injection quantity using my VCDS software, but without success.
Unfortunately, I can't find the fuel injection amount on either channel 5 or channel 1. Also, logging in with "12233" didn't work.
Is it possible that I am also unable to adjust the fuel injection quantity using VCDS with my specific engine control unit (ECU)?
major
 File size:  73.55 KB
 Viewed:  12209 times
Passat 3BG, 2.0 TDI, 100KW, MKB: BGW
Touran 2.0 TDI, 125 KW, MKB: BMN
Translated on 18-08-2026, 19:12.
Post17-12-2013, 7:42    Subject: Fuel Injection for Hot Starts Quote
major wrote:
Is it possible that I cannot adjust the fuel injection quantity using VCDS with my BMN engine?
Given that several years have passed since the introduction of ASZ engines and that there's also a significant difference between distributor injection pumps and pump-nozzle engines, I strongly suspect that the described procedure will no longer work.
Greetings.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It can also be used as a verb, meaning "to gust."
Translated on 18-08-2026, 19:14.
Wiesel
Post17-12-2013, 9:28    Subject: Quote
Unfortunately, the BMN is also a PPD.
So, it doesn't have a Bosch engine control unit.
Since the adaptation channels are not consistent even within Bosch itself,
The question is to what extent their integration is part of the requirements specification for Volkswagen.
and what Siemens has implemented regarding it.
Micha
Translated on 18-08-2026, 19:15.
major
Post13-01-2014, 11:49    Subject: Warm Start Issues: Troubleshooting & Solutions Quote
I think I've probably found a clue.
The engine speed measured with VCDS is approximately 265 RPM when idling, while various sources indicate that it should be at least 280 RPM.
Is that correct?
Translated on 18-08-2026, 19:16.
Post14-01-2014, 17:23    Subject: Warm Start Issues: Troubleshooting & Solutions Quote
major wrote:
Is that correct?
Yes, there are usually problems with speeds below 280 upm.
Translated on 18-08-2026, 19:17.
vwSchrauber
Post18-03-2014, 12:45    Subject: Quote
Solution: Replace the starter motor, or have a chip tuner with expertise correct the starting fuel mixture. These warm-starting problems are not new icon_wink.gif.
Wiesel
Post18-03-2014, 16:12    Subject: Quote
vwSchrauber wrote:
Solution: Replace the starter motor, or have a knowledgeable chip tuner adjust the starting fuel mixture. The warm start problems are not new icon_wink.gif
Or via a small timer, using the coolant temperature sensor signal.
Set it to "cold" for a few seconds (and then start it during that time).
Micha
Translated on 18-08-2026, 19:18.
vwSchrauber
Post21-03-2014, 13:00    Subject: Quote
Or via a small timer, the coolant temperature sensor signal.
Of course, undoubtedly the cheapest option, but also the most "Russian"-style solution icon_lol.gif.
Translated on 18-08-2026, 19:19.
Wiesel
Post24-03-2014, 9:21    Subject: Translating...
[Translating...]
No new posts Injection Volume: Optimize Fuel Efficiency Diesel Engine Technology
No new posts Einspritzmenge 1Z tdi 08-'94 Diesel Engine Technology
No new posts AFN: RWG and Injection Quantity Explained On-Board Diagnostics (OBD)
No new posts VAG-COM: Adjust Fuel Injection Amount Diesel Engine Technology
