sollte eigentlich gehen. See also:
The "trick" is to carefully read the menu options and select the correct ones!
Sometimes it's easy to forget something; recently, with my Audi A6 4F, I had to select three different entries before the longlife service interval was correctly reset.
If anything is missing, you can see it in the table where the values for the adjustment channels are displayed. Please check if all of those values seem reasonable.
Translated on 20-08-2026, 20:58.
