Buy BKD Engine: Pros & Cons
Post26-05-2014, 8:28    Subject: Buy BKD Engine: Pros & Cons Quote
Hi.
A colleague has apparently ended his BMW era and, after searching for an A3 8L, he is now looking for an 8P. He finally wants to get a diesel icon_smile.gif.
Now, BKD or, later, BMM are among the leading contenders.
How are the cylinder head problems of the early BKDs viewed?
Were they not "defeated" at some point?
Does anyone know when the BKD engine will be "available for purchase," or should people avoid this first 16V experiment?
The BMM engine quickly filled up its particulate filter (DPF) according to its owner's assessment. However, it might be more sensible to have the DPF cleaned rather than buying a new 16V cylinder head!
Thank you for your opinions.
Translated on 09-09-2026, 21:17.
Post26-05-2014, 9:03    Subject: Buy BKD Engine: Pros & Cons Quote
Hello Martin,
Do both engines have EU4 compliance? If so, there shouldn't be any difference regarding the "highway robbery" sticker or the German vehicle tax.
Regarding the BKD engine: The cars likely have mileage well over 100,000 km. If the timing chain was prone to failure, it would have likely been replaced already, so it shouldn't be causing any problems now.
Translated on 09-09-2026, 21:19.
Post26-05-2014, 9:18    Subject: Buy BKD Engine: Pros & Cons Quote
Yes.
To the best of my knowledge, the BKD also receives the green sticker.
And that's true, because if the head is already new icon_smile.gif, then the BKD engine might be even more interesting, because with high mileage, you won't have any issues with a DPF.
Translated on 09-09-2026, 21:20.
Post26-05-2014, 10:11    Subject: Buy BKD Engine: Pros & Cons Quote
dieselmartin wrote:
And that's true, because if the engine head is already new,icon_smile.gif then the BKD engine might be even more interesting, because with high mileage, you don't have to worry about a DPF.
Okay. The repair must have been done properly, and it's great to have a newer ZK (presumably referring to a specific component or device) in that case.
So, even so, pay attention to starting problems and the coolant level. It's best to briefly get onto the highway and really step on the gas.
Regarding crack issues:
Translated on 09-09-2026, 21:21.
alevuz
Karma: +32 / -0   Thank you, like it!
Post27-05-2014, 9:20    Subject: Buy BKD Engine: Pros & Cons Quote
Good morning!
I have this car - it's been completely trouble-free except for a new turbo at 190,000 km - and it gets a green sticker, even WITHOUT the DPF nonsense. It's worth noting that my AYH even has better emissions values than the BKD, but the latter is only Euro 3. Someone should actually know something about cars and not just think about making money... icon_lol.gif
Shouldn't leaks in the PDE (positive displacement element) be less frequent in the engine since they are "double-flanged" (i.e., without a wedge)? Or am I mistaken?
Here's an excerpt from another article (I cannot verify its accuracy!) regarding the cylinder head issue:
Currently, it has 220,000 kilometers on the odometer!
2.0 4V TDI Coolant loss with and without difficulty starting after standstill.
Problem description.
1. Coolant leak.
2. The engine starts poorly after a long period of inactivity (approximately 10-12 hours). There is a significant amount of white smoke coming from the exhaust.
The cause of this is a hairline crack in the water jacket of the cylinder head. This allows coolant to leak into the combustion chamber.
A production issue affecting a series of vehicles started with engine number:
BKD 402 570 } Motorenwerk Salzgitter, identification number 17.
BKD 178 692 } Motorenwerk Györ, identification number 26.
All BKD engines up to these engine numbers may be affected. The factory code and engine number can be found on the sticker located on the timing belt cover, under the engine cover.
As a customer service solution, the engine number and build configuration are first determined. Then, different tests are performed depending on the build configuration. Tests are conducted to check for pressure losses in the cooling system, the exhaust cooler is checked for leaks, etc. If a pressure loss is detected or if coolant is present in the cylinder, the cylinder head is replaced.
Cylinder heads for which the reason for the complaint cannot be determined must not be replaced!
SG
Alevuz.
Touareg V10 TDI (AYH)
Translated on 09-09-2026, 21:24.
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Passat 3C or Superb 3T emergency unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A6 2.5 TDI AKN: Buy or Not? (VW Audi) Diesel Engine Technology
No new posts Buy or Not Buy! Diesel Engine Technology
No new posts Ball joints: buy new or replace bushings? Transmission, Chassis, Body & Interior
No new posts VW 1.6 TDI: Buy, Wait, or Avoid? Diesel Engine Technology
