Fuel Injector Torque Specs - Ford Focus
wutz
Karma: +11 / -1   Thank you, like it!
2006 Seat Leon
Post04-07-2014, 10:57    Subject: Fuel Injector Torque Specs - Ford Focus Quote
Ford Focus MK1 Facelift, year 2003, 90 horsepower, 1.8 TDDI (the one with the rotary injection pump).
I had the fuel injectors checked and I'm now reinstalling them.
I need the torque specifications for the injector hold-down clamps.
Are the sealing rings (copper washers) annealed? I asked at our workshop, and one mechanic said yes, while another said no.
Michael.
Translated on 18-10-2026, 12:41.
Post04-07-2014, 10:59    Subject: Fuel Injector Torque Specs - Ford Focus Quote
Are the sealing rings (copper washers) annealed to soften them?
Translated on 18-10-2026, 12:42.
wutz
2006 Seat Leon
Post04-07-2014, 16:18    Subject: Fuel Injector Torque Specs - Ford Focus Quote
I also bought some new ones and installed them.
I couldn't find the correct torque specification for the retaining bolts, so I tightened them to 50 Nm.
The initial test run was also successful; the engine starts and runs smoothly.
Now I just need to figure out why the rear brake is always sticking on one side.
Translated on 18-10-2026, 12:43.
Post04-07-2014, 16:57    Subject: Fuel Injector Torque Specs - Ford Focus Quote
You can check the airtightness with dish soap; if it doesn't bubble, it's airtight.
Translated on 18-10-2026, 12:44.
wutz
2006 Seat Leon
Post04-07-2014, 18:30    Subject: Fuel Injector Torque Specs - Ford Focus Quote
Thank you for the tip, I will try it out.
I also found a problem with the brakes. The new replacement part (brake caliper) is defective.
Post04-07-2014, 20:53    Subject: Fuel Injector Torque Specs - Ford Focus Quote
50 Nm is definitely not too low.
Post04-07-2014, 21:44    Subject: Fuel Injector Torque Specs - Ford Focus Quote
Translated on 18-10-2026, 12:45.
No new posts Ford Focus 1.6 TDCi - Error code P1181 General Tips
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Crankshaft bolt torque specification ALH G4 Diesel Engine Technology
No new posts Cylinder Head Bolt Torque Specs 1Z Diesel Engine Technology
No new posts Tightening Torque: 16V PD Camshaft Diesel Engine Technology
No new posts Torque Specs: Nozzle Tip Over-Molded Nuts (VEP ESD) Diesel Engine Technology
