kossmann Blaumann
2016 Audi Q3 Premium Support
24-07-2014, 15:45 Subject: AGR Valve Problems: Modern Engines & DPF Issues |
Hello everyone,
A sealed AGR valve with a metal plate has sometimes worked wonders in older TDIs (e.g., 1Z). Can the same approach be used with modern engines (e.g., CFGx), or are there any problems associated with it?
Is the DPF potentially subjected to greater stress due to a blocked EGR valve?
Translated on 14-10-2026, 17:55.
Profile PM Email Garage |
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2405 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
24-07-2014, 17:43 Subject: AGR Valve Problems: Modern Engines & DPF Issues |
Meanwhile, engine control units (ECUs) have also become much more sophisticated and will therefore immediately recognize this modification and set an error code. The air mass measured by the mass airflow sensor (MAF) is significantly higher in the partial load range and can no longer be regulated to the desired low target value due to the activation (or deactivation) of the exhaust gas recirculation (EGR) system.
With the error code set, the OBD error light will illuminate, and the next vehicle inspection will fail due to it.
I also had it on my Golf 3 with the AHU engine (to prevent carbon buildup/sludge in the intake manifold). But the only other memory I have of the closed EGR system was the extremely long warm-up times. Therefore, I wouldn't do it again today.
Greetings.
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Translated on 14-10-2026, 17:56.
Profile PM Garage |
chli1976 Profi-Schrauber
25-07-2014, 5:41 Subject: AGR Valve Problems: Modern Engines & DPF Issues |
You can deactivate the AGR (Abgasrückführung) in the engine control unit, but doing so will invalidate the operating license. VCDS
Translated on 14-10-2026, 17:57.
matthiasTDI96 Profi-Schrauber
25-07-2014, 7:03 Subject: AGR Valve Problems: Modern Engines & DPF Issues |
Alternatively, you could put in the effort to research past issues instead of rehashing the same old arguments. Besides that, the previous speaker said everything that needed to be said by mentioning the operating license.
Translated on 14-10-2026, 17:58.
