GRA errors after AHK installation, Roomster 2010
felix
Avatar-felix
Post18-10-2014, 20:40    Subject: GRA errors after AHK installation, Roomster 2010 Quote
I retrofitted a Westfalia tow hitch to our Roomster 1.6 TDI, which was manufactured in 10/2010.
Since then, I've been getting a GRA error.
Ideas:
1. Encoding error.
2. The (guilt-inducing) crimp connector on a CAN bus cable.
The others had popped out, but I couldn't get this micro pin out of the connector housing due to the tight space.
3. Some cable is damaged.
Attached are two log files.
The first time should be done immediately after the last trip, and the second time after clearing all errors and turning the GRA on and off once.
Does anyone have any ideas?
Log-IRIS ROOMSTER-TMBNL65J0B5019669.txt
 File name:  Log-IRIS ROOMSTER-TMBNL65J0B5019669.txt
 File size:  18.66 KB
 Downloaded:  989 times
Gruß Felix
E91 330d, 1/2009
Translated on 09-07-2026, 9:33.
Post18-10-2014, 21:35    Subject: GRA errors after AHK installation, Roomster 2010 Quote
You should truly begin icon_wink.gif with checking the wiring.
If it's okay, could you try disconnecting the control unit (STG) completely and see if the GRA error disappears?
Translated on 09-07-2026, 9:35.
felix
Avatar-felix
Post18-10-2014, 22:19    Subject: GRA errors after AHK installation, Roomster 2010 Quote
Thank you.
I was afraid that I might have to reach under the dashboard again. icon_confused.gif
Gruß Felix
E91 330d, 1/2009
No new posts Roomster Tailgate Won't Open: Remote Button Issue Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Installation of an aftermarket seat heater Troubleshooting & Guides
No new posts RNS2 Installation: Control Unit Errors On-Board Diagnostics (OBD)
No new posts vw Polo 6C Front Assist error after trailer hitch install... On-Board Diagnostics (OBD)
No new posts GRA Supplemental Restraint System (SRS) Installation Erro... On-Board Diagnostics (OBD)
No new posts ACC Coding for A4 B8 FL After AHK Installation On-Board Diagnostics (OBD)
