Water Leak Golf 4: Causes & Fixes
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Karma: +585 / -0   Thank you, like it!
Post22-10-2014, 20:09    Subject: Water Leak Golf 4: Causes & Fixes Quote
Hi!
My car (a 4-series) had a small water leak near the passenger-side door today due to the bad weather.
I saw it, a small stream of water, coming from near the passenger door, about a quarter of the way from the front, and running over the inner plastic trim of the rocker panel.
It ran into the footwell.
I checked the door seals, and they are completely undamaged.
The water drainage channels in the door are also clear.
Does anyone have any ideas, or know of a common vulnerability?
Translated on 28-08-2026, 11:02.
Post22-10-2014, 20:52    Subject: Water Leak Golf 4: Causes & Fixes Quote
The foam rubber seal on the door's carrier is deteriorating.
Translated on 28-08-2026, 11:03.
Post22-10-2014, 21:29    Subject: Water Leak Golf 4: Causes & Fixes Quote
Windshield bonding loose/leaking.
Post23-10-2014, 9:53    Subject: Water Leak Golf 4: Causes & Fixes Quote
Finding the source of the water leak should be relatively simple. Get an assistant and a garden hose. One person should observe the interior door sill trim, while the other starts watering the vehicle, beginning at the door.
Post23-10-2014, 10:26    Subject: Water Leak Golf 4: Causes & Fixes Quote
That should be relatively easy to find
Theoretically, yes, it's annoying when water first runs along coverings and edges inside, before dripping out somewhere completely different. icon_wink.gif
The only solution then is to dismantle everything and trace the steps back.
Translated on 28-08-2026, 11:04.
haithamina
Post23-10-2014, 14:02    Subject: Water Leak Golf 4: Causes & Fixes Quote
It is definitely the casting that acts as the aggregate carrier, as previously mentioned.
Simply use this sealant/paste (e.g., an original VW replacement part) and it should be fine. The tricky part is the handle attachment and the reinstallation of the cylinder lock. However, it should be easier to do on the passenger side.
haithamina
Translated on 28-08-2026, 11:05.
Post23-10-2014, 19:09    Subject: Water Leak Golf 4: Causes & Fixes Quote
Hello!
Thank you for the answers.
So, I already repaired something on the door a few years ago, which is a starting point.
Today, we washed the car with the hose; my father held the hose, and I used a flashlight inside the car.
However, after 10 minutes, nothing was visible.
Well, I'll keep an eye on it.
Let's dust the suspicious area near the door.
Perhaps I'll see some signs of water there sometime.
So that I can tell whether it's coming from the door panel or not.
Translated on 28-08-2026, 11:06.
Post24-10-2014, 14:57    Subject: Water Leak Golf 4: Causes & Fixes Quote
TDI-GTI-4-Motion wrote:
The foam rubber seal on the door's aggregate carrier is rotting.
Translated on 28-08-2026, 11:07.
Holger247
Post24-10-2014, 15:44    Subject: Water Leak Golf 4: Causes & Fixes Quote
Hello everyone,
There used to be an online guide from Seat for the same problem on the Leon. It used a black sealing strip, part number "AKD 497 010 04R10", to reseal it. I used the same method, and it's been holding up for several years.
(If not already done, it's best to also replace the front window regulators at the same time).
Additional water sources in the "4er" category would be:
- Front water reservoir: Leak between the pollen filter housing and the water reservoir cover (located in the passenger footwell).
- Rear taillight seal leaking.
- Seal of the forced ventilation system is leaking.
- Sunroof drain tubes are clogged/dislodged.
GIV - 98 - ALH
Touran 5T 2.0 TDI
Translated on 28-08-2026, 11:08.
No new posts Document: Golf IV / Octavia 1 Water ingress at the doors Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wassereinbruch GolfIV Transmission, Chassis, Body & Interior
No new posts Water Leak Audi A3 8L (1998) Fix Transmission, Chassis, Body & Interior
No new posts Water leak? Wet seatbelt Transmission, Chassis, Body & Interior
No new posts Water ingress door Passat 3B Transmission, Chassis, Body & Interior
