If you had just read a little bit of the old posts and the quiz, you would have come across a topic about pre-emptive injections in PD (Parkinson's Disease).
- The PD also has a pre-injection feature.
- The PD engine makes more noise (especially when cold) because the fuel injection pressure is higher than in the VP engine.
"This noise problem is common to all high-pressure injection systems. It is only through the pre-injection process that the pressure increase in the cylinder is reduced sufficiently to achieve a reduction in noise."
"With a PD engine, there's a noise that isn't related to the combustion process, but it can be mistaken for it (as it's sometimes louder than the actual combustion sound). The solenoid valves make a hissing (ticking) sound – this noise is not present during idling. This particular sound is a clear indicator of a PD engine."
If the Piezo PD elements are from Siemens VDO, then that noise will also disappear. Gruß Bertil
Translated on 26-10-2026, 18:10.
