GKB MVS Transmission Data (A4B8)
Post07-12-2014, 19:49    Subject: GKB MVS Transmission Data (A4B8) Quote
I am looking for the gear ratios (gears, intermediate shaft, driveshaft) for the mechanical 6-speed transmission in the A4 B8, where GKB is MVS.
Unfortunately, the RLF (Regionaler Landschaftsplan) doesn't provide any information, but instead refers to the ET KA (Entwicklungsplanung Landschaft).
Does anyone have any of that?
Translated on 10-09-2026, 6:00.
Hans Dampf
Karma: +9 / -0   Thank you, like it!
2013 Ford Galaxy
Post10-12-2014, 12:17    Subject: GKB MVS Transmission Data (A4B8) Quote
I can find this information using the vehicle's European Whole Vehicle Type Approval (EWVT) certificate. To do so, I need a photo of the vehicle registration document, but please send it to me via private message (PM) without any owner details or the vehicle identification number (VIN).
Sincerely,
Benny.
Audi A4 AKE
Translated on 10-09-2026, 6:01.
Post10-12-2014, 20:08    Subject: GKB MVS Transmission Data (A4B8) Quote
What exactly do you need from the document? The number under the letter K?
Translated on 10-09-2026, 6:02.
Hans Dampf
2013 Ford Galaxy
Autoservice likes this.
Post10-12-2014, 23:35    Subject: GKB MVS Transmission Data (A4B8) Quote
Good evening, I saw your answer/question late. I've already figured out the translations. It was a bit more work doing it "only with GKB," but hopefully, it worked out.
Please double-check your data; if anything seems completely incorrect, I will review it again.
Your European Whole Vehicle Type Approval (EWVT) number (field "K") should be: e1*2001/116*0430* ab" 28" or a higher number.
Engine code: CJCD, 110 kW.
The internal gearbox code is: FM6B1002.
Whether it's an Avant or a sedan, it doesn't matter.
Unfortunately, I'm not able to insert a table here, so I'll have to present it in a less organized way.
1st gear = lowest gear.
2nd number = gear ratio.
3rd digit = translation of the axle gear ratio.
4th number = overall gear ratio.
1. 3,778 3,490 13,185
2. 2,050 3,490 7,155
3. 1,321 3,490 4,610
4. 0.970 3.490 3.385
5. 0.757 3.490 2.642
6. 0.625 3.490 2.181
R. 3.333 3.490 11.632
I hope I was able to help.
Sincerely,
Benny.
Audi A4 AKE
Translated on 10-09-2026, 6:04.
Post11-12-2014, 9:16    Subject: GKB MVS Transmission Data (A4B8) Quote
Thank you.
You are right about the EC number; the last block of digits is 30.
Unfortunately, the overall translation isn't quite accurate. For example, I drive in 6th gear at 120 km/h with the engine running at 2000 rpm. With a wheel circumference of 1.988 meters, the overall gear ratio should then be 1.99. Does the intermediate gear play a role in this? I only see different diameters of the gears in the overview in the RLF (presumably a technical manual or software).
Translated on 10-09-2026, 6:07.
Hans Dampf
2013 Ford Galaxy
Post11-12-2014, 9:48    Subject: GKB MVS Transmission Data (A4B8) Quote
What is the tire size you have?
Best regards, Benny.
Audi A4 AKE
Translated on 10-09-2026, 6:08.
Hans Dampf
2013 Ford Galaxy
Post11-12-2014, 10:52    Subject: GKB MVS Transmission Data (A4B8) Quote
Does field "D.2" in your registration document say:
B8
ACJCDF1
FM6B1002RB8KAS57MJEM1
or
B8
ACJCDF1
FM6B1002RB8K1S57MJEM1 ???
I achieve a speed of 110.42 km/h with the standard tire size of 225/50 R17 (taking into account the dynamic rolling radius). The rolling circumference for that tire size is 2007mm. Where did you get the 1988mm figure from?
Are you absolutely sure that it's exactly 2000 RPM? If you calculate everything based on 2100 RPM, you get 115.94 km/h.
Audi A4 AKE
Translated on 10-09-2026, 6:09.
Post11-12-2014, 23:25    Subject: GKB MVS Transmission Data (A4B8) Quote
The tire size is 225/55 R 16, which results in a height of almost exactly 2 meters. icon_wink.gif The speed can be read accurately enough.
Translated on 10-09-2026, 6:10.
Hans Dampf
2013 Ford Galaxy
Post12-12-2014, 20:16    Subject: GKB MVS Transmission Data (A4B8) Quote
Is "D.2" exactly how it's written on your vehicle registration document?
Audi A4 AKE
Translated on 10-09-2026, 6:11.
Post13-12-2014, 18:25    Subject: GKB MVS Transmission Data (A4B8) Quote
I've checked it again, and the engine speed is approximately 2150 RPM in 6th gear at 120 km/h (both readings were taken directly).
Dann kommt das mit der Gesamtübersetzung von 2,18 im 6. Already went.
I'll get more details from analyzing the log files.
Thanks again, and also for your patience!
Hans Dampf
2013 Ford Galaxy
Post13-12-2014, 19:23    Subject: GKB MVS Transmission Data (A4B8) Quote
No problem icon_wink.gif.
Audi A4 AKE
Translated on 10-09-2026, 6:12.
