Audi A6 Engine Regeneration: CDYA Model
Ismail1982
2015 Volkswagen Touran
Post25-01-2015, 20:08    Subject: Audi A6 Engine Regeneration: CDYA Model Quote
Hello everyone. I noticed that I had made a typo, so I deleted the post to correct it and repost it properly.
I wanted to regenerate the diesel particulate filter (DPF) on an Audi A6, model year 2010, using VCDS.
Unfortunately, it didn't work because the VAT system did not accept code 10016.
I found a topic about regenerating the DPF, but the engine code doesn't match.
Is there a specific login code for the CDYA engine code?
Please help me.
Thank you in advance, Ismail.
Translated on 23-07-2026, 22:37.
Post25-01-2015, 20:45    Subject: Audi A6 Engine Regeneration: CDYA Model Quote
Hello Ismail,
Does VCDS not display the code when you hover your mouse cursor over the corresponding input field?
Please provide the VAG part number for the engine control unit, preferably a Screenshot (without the vehicle identification number).
Translated on 23-07-2026, 22:38.
Ismail1982
Post26-01-2015, 15:46    Subject: Audi A6 Engine Regeneration: CDYA Model Quote
dieselschrauber wrote:
Hello Ismail,
Best regards, Rainer
Hello Rainer. I don't have an auto-scanner, but I only have this.
Adresse 01: Motorelektronik Labeldatei: UMLEIT. FAILURE!
Control unit part number: 4F9 910 402 A. Hardware: 4F0 907 401 E.
Component and/or version: 3.0 TDI EDC17G000AG 0080.
Encoding: 0105002C190F0128
Company number: WSC 18176 551 682054
VCID: 24426A8EE7647E3EDF5-8071
Does that help you?
Ismail
Translated on 23-07-2026, 22:40.
Ismail1982
Post26-01-2015, 16:12    Subject: Audi A6 Engine Regeneration: CDYA Model Quote
Hello Ismail,
Hello Rainer. I don't have an automatic scanner, but I only have this.
Does that help you?
Sincerely,
Ismail
"Edit: Hi Rainer. What I missed is that my laptop didn't install the update for the new version of VCDS. I've now installed it and will try again. I'll let you know if it works."
MFG Ismail
Translated on 23-07-2026, 22:43.
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MSA15 engine: From which engine number? Diesel Engine Technology
No new posts 3.0 TDI CDYA - AGR valve stuck open at 99.6% + RPM fluctu... On-Board Diagnostics (OBD)
No new posts When is the DPF full on a 3.0 TDI engine (with ASB or CDY... Diesel Engine Technology
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
