Touareg 2.5 TDI Battery Replacement (2008)
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Karma: +1102 / -0   Thank you, like it!
Post03-02-2015, 6:20    Subject: Touareg 2.5 TDI Battery Replacement (2008) Quote
Okay, let me bring up a question from my circle of friends. A 2008 Touareg 2.5 TDI needs a new battery. It was ordered using the part number and has now arrived. The vehicle battery is supposed to be located under the driver's seat. What's the least invasive way to access it? Is there possibly a second battery? Would an uninterruptible battery change make sense, or is it perhaps even absolutely necessary?
Translated on 09-09-2026, 4:27.
Post03-02-2015, 7:52    Subject: Touareg 2.5 TDI Battery Replacement (2008) Quote
Adjust the driver's seat to the rearmost position. Carefully remove the plastic covers located at the junction between the seat base and the floor. Unscrew the two Torx screws underneath. Fold the seat back almost completely, and the battery compartment should then be clearly visible in front of you.
In my opinion, the battery replacement should be possible without any external support.
To the best of my knowledge, there have always been two batteries in the ship's diesel engine (V10), and likely also in other engines if a stand-alone heater is installed. The second battery should be located in the trunk, but I have no idea exactly where.
Translated on 09-09-2026, 4:28.
Post03-02-2015, 8:10    Subject: Touareg 2.5 TDI Battery Replacement (2008) Quote
Thanks in advance! We're hoping the battery will last until the weekend, so we won't have to replace it outdoors. I'll let you know how it goes.
Translated on 09-09-2026, 4:29.
Post03-02-2015, 8:28    Subject: Touareg 2.5 TDI Battery Replacement (2008) Quote
Let's put it this way: It's nothing special.
Post03-02-2015, 8:44    Subject: Touareg 2.5 TDI Battery Replacement (2008) Quote
Let's hope so!
I also have to fix this stupid rearview camera; it's not displaying an image anymore. But hey, at least it's definitely the wrong time of year for that!
Translated on 09-09-2026, 4:30.
Karma: +591 / -0   Thank you, like it!
Post04-02-2015, 19:48    Subject: Touareg 2.5 TDI Battery Replacement (2008) Quote
Hi!
Does it sometimes need to be trained?
I don't want to spread any panic here, but this sometimes happens with newer and more expensive cars.
Post04-02-2015, 19:54    Subject: Touareg 2.5 TDI Battery Replacement (2008) Quote
If my memory serves me correctly, this is a conventional Bleisaeuerling battery, not an AGM battery. The purchased battery size should match the installed one. For convenience, I agreed to buffer the Touareg with a large power supply to enable a seamless battery replacement.
Translated on 09-09-2026, 4:31.
Post04-02-2015, 20:09    Subject: Touareg 2.5 TDI Battery Replacement (2008) Quote
Why would a 2.5 engine need an AGM battery... Start-Stop technology wasn't even available then.
Post04-02-2015, 22:52    Subject: Touareg 2.5 TDI Battery Replacement (2008) Quote
matthiasTDI96 wrote:
Why would a 2.5 engine have an AGM battery... Start-Stop technology wasn't available then...
A 05 A6 4F also has an AGM battery with coding. This isn't necessarily related to Start-Stop. icon_wink.gif
However, the Touareg in question doesn't have that problem; you just need to replace the battery and it's fixed.
Translated on 09-09-2026, 4:32.
Post05-02-2015, 0:50    Subject: Touareg 2.5 TDI Battery Replacement (2008) Quote
Could you please address the issue again?
So, how can I tell if a car battery needs to be registered?
Or where that is not necessary.
Post05-02-2015, 7:05    Subject: Touareg 2.5 TDI Battery Replacement (2008) Quote
Okay, I've learned something new. What's the point of AGM batteries from the manufacturer's perspective, then? Is there a form of regenerative braking involved? To the best of my knowledge (which is admittedly incomplete), a small AGM battery is more expensive than a larger conventional battery. But it's good to know that these combinations exist. So far, I've only seen conventional batteries in very new cars, especially if they don't have a start-stop system.
Nevertheless, I believe that the battery replacement should not be complicated on that particular Tuareg model. Just release the seat, open the compartment, take out the battery, put in a new one, and you're done.
Translated on 09-09-2026, 4:33.
Post05-02-2015, 8:43    Subject: Touareg 2.5 TDI Battery Replacement (2008) Quote
Ah, I've learned something new. What's the point of the AGM battery from the manufacturer's perspective? Is there a kind of regenerative braking system?
In the A6 4F and A8 4E, for example, even with the largest diesel engine and full equipment, including a standing heater, there is no secondary battery.
Translated on 09-09-2026, 4:34.
Post06-02-2015, 11:26    Subject: Touareg 2.5 TDI Battery Replacement (2008) Quote
But that still doesn't explain the "advantage" of using an AGM battery here.
My current information regarding the VKs - there will definitely be a difference with the EK icon_smile.gif.
68 Ah AGM battery - €313 at VW/Audi.
72 Ah lead-acid battery - €185 at VW/Audi.
The B6 Passat has the 72-size AGM battery, while the B8 Passat has the 68-size AGM battery.
My B6 is currently running with a 68Ah AGM battery.
The nominal starting currents are the same.
So, you get a TDI started with both of them icon_smile.gif.
... why would there be an AGM in room 4F?
Possibly because AGMs start better, as they have a lower internal resistance (according to Wikipedia).
Translated on 09-09-2026, 4:36.
Post06-02-2015, 12:45    Subject: Touareg 2.5 TDI Battery Replacement (2008) Quote
. A lower internal resistance would generally result in a higher normal cold-start current;).
Are AGM batteries not more resistant to cyclic stress? Then, for example, high resting currents in a parked car would be an argument in favor of using AGM batteries.
Translated on 09-09-2026, 4:37.
Post06-02-2015, 20:04    Subject: Touareg 2.5 TDI Battery Replacement (2008) Quote
dieselmartin wrote:
But that doesn't explain the "advantage" of using an AGM battery here.
AGMs provide more capacity, especially at lower temperatures, and that's where I think the advantage lies for large diesel engines with a heater without a second battery. icon_wink.gif
Translated on 09-09-2026, 4:38.
Post09-02-2015, 18:24    Subject: Touareg 2.5 TDI Battery Replacement (2008) Quote
Ready. It took an hour. icon_peinlich.gif The automatic start function is working again.
The expanded Moll was from the 46th calendar week of 2007. When it was subjected to the initial current, it ultimately became overloaded.
 File size:  87.16 KB
 Viewed:  4828 times
 File size:  60.11 KB
 Viewed:  3866 times
 File size:  96.21 KB
 Viewed:  11570 times
Translated on 09-09-2026, 4:39.
No new posts Doku Touareg, Transmission in Emergency Mode Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dacia/Renault Duster, squeaking noises steering column / ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touareg documentation, clacking sounds coming from the st... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touareg R50 V10 Diesel Engine Technology
No new posts Touareg GRA.... On-Board Diagnostics (OBD)
No new posts Touareg 7P 2013 DWA System Electrical Systems, Vehicle Electronics, Multimedia
No new posts VW Touareg: 3.0 TDI Problems & Solutions Diesel Engine Technology
