A3 8L 1.8T Quattro: Incorrect ABS Coding
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post01-02-2015, 18:15    Subject: A3 8L 1.8T Quattro: Incorrect ABS Coding Quote
I had the A3 mentioned above with me last week.
The ABS and ESP warning lights occasionally illuminate and usually turn off after restarting the engine.
According to the diagnostic trouble codes, the control unit is incorrectly coded. Unfortunately, I don't have the necessary information for this vehicle in VCDS, so I can't correct the coding.
Please find the Autoscan attached. I hope you can help me.
Greetings.
Monday, January 26, 2015, 19:58:02:58542
VCDS -- A Windows-based VAG/VAS emulator.
VCDS Version: 12.12.0.0
Data as of: 20131116.
Mileage: 165,640 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Vehicle type: 8L - Audi A3/S3 (1997 > 2003)
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
Mileage: 165,640 km
Address 01: Engine Control Unit
Label file: None
Part number: 06A 906 032 AC
Component: 1.8L R4/5VT 01 0002
Coding: 05700
Operating number: WSC 06435
VCID: 5FCB9554DDD932E6CD9-5178
No error codes found.
Readiness: 0000 0000
Address 03: Brake Electronics
Label file: 1J0-907-37x-ESP-A.lbl
Part number: 1J0 907 379 AB
Component: ESP 20 CAN V005
Encoding: 00214
VCID: 71EFE3EC3B4DB4966BD-4B32
"One error found:"
01044 - Control unit incorrectly coded.
35-10 - - - Sporadically
Address 08: Climate Control. Label file: RKS\8L0-820-043-2D.lbl
Part number: 8L0 820 043 M
Component: A3 CLIMATE CONTROL FULL AUTOMATIC SYSTEM_D77
Coding: 03140
VCID: 326D2CE0FECBCF8E527-25B8
Address 15: Airbag
Label file: RKS\8L0-959-655-AI8.lbl
Part number: 8L0 959 655 G
Component: Front and Side Airbag 1008.
Encoding: 00104
VCID: 428D7C204E6B7F0EC27-5178
Address 17: Control unit insert
Label file: RKS\8L0-920-xxx-17.lbl
Part number: 8L0 920 900 A
Bauteil: AB-KOMBIINSTR. VDO D09
Encoding: 05044
Operating number: WSC 00000
VCID: 295FCB8CD31D8C56E3D-515A
Part number: AUZ7Z0X1268430
Unfortunately, I am unable to translate the provided text as it appears to be a sequence of non-standard characters rather than a coherent German sentence. It is likely corrupted data.
"One error found:"
01039 - Coolant temperature sensor (G2).
30-10 - Interruption / Short circuit after positive voltage - Occasional.
Address 22: All-wheel drive
Label file: RKS\02D-900-554.lbl
Part number: 02D 900 554 B.
Component: HALDEX LSC ECC 0006.
VCID: 1F4BD5549D5972E68D9-4B18
Address 35: Central Locking
Label file: RKS\8D0-862-257.lbl
Part number: 8L0 862 257 K
Component: Central locking pump, radio. D11.
Encoding: 12864
VCID: 3D770FDC379500F6BF5-4F3A
2 error codes found:
00991 - Interior lighting.
28-00 - Short circuit to positive.
00956 - Key 2
09:00 - Adaptation limit exceeded.
Address 56: Radio
Label file: RKS\8D0-035-1xx-56.lbl
Part number: 4B0 035 152 B
Component: Radio 0001
Encoding: 00201
VCID: 1839FE48787705DE4C3-4B18
00856 - Antenna; for the radio.
36-00 - Interruption.
00852 - Front speakers.
36-10 - Interruption - Sporadic.
End.
Translated on 07-10-2026, 14:45.
Post02-02-2015, 10:49    Subject: A3 8L 1.8T Quattro: Incorrect ABS Coding Quote
It's not necessarily the case that the ABS/ESP is incorrectly coded. I believe it's more likely that other control units in the vehicle have been replaced or modified, and as a result, the ABS/ESP is now missing certain signals or receiving signals that are different from what it expects.
I would first clear the error code, investigate the vehicle's history, perform a function test, and see if the error reappears.
Translated on 07-10-2026, 14:56.
klahaui
Avatar-klahaui
Post02-02-2015, 16:08    Subject: A3 8L 1.8T Quattro: Incorrect ABS Coding Quote
Hello Rainer,
The error was cleared, but immediately reappeared sporadically. On the third or fourth attempt, it didn't reappear.
The ESP and ABS warning lights then turned off, but came back on a few days later.
The vehicle was purchased in January 2014 and first used in November.
Since I purchased the vehicle, I have been responsible for its maintenance, and no engine control units (ECUs) have been replaced since then.
Could the ABS control unit be defective, causing this error?
If the fault is not currently active, both the ABS and ESP systems will function as intended.
Translated on 07-10-2026, 14:58.
Post02-02-2015, 16:10    Subject: A3 8L 1.8T Quattro: Incorrect ABS Coding Quote
Perhaps update VCDS to the latest version (14.xx), as label files are frequently added or updated.
Translated on 07-10-2026, 14:59.
Post02-02-2015, 16:35    Subject: A3 8L 1.8T Quattro: Incorrect ABS Coding Quote
Could the ABS control unit be defective, causing this error to occur?
Possibly, because I only found vehicles with the engine control unit and ABS/ESP systems that you specified, as well as the exact coding you mentioned.
Do you perhaps still have the model year and the engine code?
Translated on 07-10-2026, 15:00.
klahaui
Avatar-klahaui
Post02-02-2015, 18:55    Subject: A3 8L 1.8T Quattro: Incorrect ABS Coding Quote
Finally, I updated it yesterday.
Subject Code: AQA
Model year is 2000.
Post02-02-2015, 19:02    Subject: A3 8L 1.8T Quattro: Incorrect ABS Coding Quote
Sorry, for the AQA code for different A3 8L models, I can only find the same coding that you already have entered.
klahaui
Avatar-klahaui
Post02-02-2015, 22:00    Subject: A3 8L 1.8T Quattro: Incorrect ABS Coding Quote
Too bad, but I'll keep trying. It's been unavailable again since Saturday.
I'll get back to you.
Translated on 07-10-2026, 15:01.
Post03-02-2015, 8:53    Subject: A3 8L 1.8T Quattro: Incorrect ABS Coding Quote
Ross-Tech has made some statements about this error; you might want to check them out.
http://wiki.ross-tech.com/wiki/index.php/01044#Possible_Symptoms
Here's another thought. Are the mass connections and power supply working correctly? The other errors suggest a problem in that area. The fact that a code is occasionally recognized as incorrect could also be related.
What about the second key (adaptation limit exceeded)? It might need to be reprogrammed.
klahaui
Avatar-klahaui
Post04-02-2015, 19:52    Subject: A3 8L 1.8T Quattro: Incorrect ABS Coding Quote
I inspected the mass points under the battery today.
They looked rusty, covered in verdigris, and were mostly disconnected.
Cables clipped, new shoes installed, and the areas cleaned. Let's see what happens.
Greetings.
Translated on 07-10-2026, 15:03.
klahaui
Avatar-klahaui
Post26-02-2015, 19:43    Subject: A3 8L 1.8T Quattro: Incorrect ABS Coding Quote
The error seems to be fixed, and there are no more problems with the ABS.
Thank you!
Post26-02-2015, 20:13    Subject: A3 8L 1.8T Quattro: Incorrect ABS Coding Quote
Great, thanks for the feedback!
Translated on 07-10-2026, 15:04.
No new posts Document A3 8P1 Quattro up to week 34.04, fuel tank noises. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Octavia 1 / Golf IV fuel gauge malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Control: 77 incorrectly encoded, FSE 5K0 035 730 E Electrical Systems, Vehicle Electronics, Multimedia
No new posts CAN Gateway A3 8PA: Incorrect Coding? On-Board Diagnostics (OBD)
No new posts TD 89/B3 Conversion: Upgrade to Quattro Diesel Engine Technology
No new posts A4 B5 Quattro Instrument Cluster On-Board Diagnostics (OBD)
