Audi A8 Advanced Key: Do you have it? Programming?
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Hans Dampf
Karma: +9 / -0   Thank you, like it!
2013 Ford Galaxy
Post24-11-2014, 8:48    Subject: Audi A8 Advanced Key: Do you have it? Programming? Quote
"Good day. My father owns an Audi A8 (see vehicle details below)."
To open or close the car, you need to press the "unlock" or "lock" button on the key fob. It doesn't automatically open when you pull the door handle, and I can't lock it using the button on the door handle either.
I've now checked control units 46 and 05 after the long coding process. There are several entries labeled "Advanced Key," which is indeed what this function is, but none of the bits are checked. If I want to recode the control unit and activate these bits (indicating that "Advanced Key" is installed), I get an error message after pressing the "code" button.
My question now is: How can it be recoded, or is it even possible? Could it be that the car doesn't actually have the system installed? What's inexplicable to me is that, as far as I know, all the components are present.
I hope someone can help me.
Sincerely,
Sunday, November 23, 2014, 3:56:35:07236
VCDS -- A Windows-based VAG/VAS emulator.
VCDS Version: RKS 12.12.3.0
Data as of: 20140904.
Vehicle Identification Number: WAUZZZ4H7BN015194 License plate:
Mileage: 58332
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Vehicle type: 4H (4H0)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 18 19 20 28 34 36 3B 3C
42 46 47 52 53 56 57 _ 62 6C 6D 6F 72 81 85 88 89 8B 8E 8F
90
01-Motor electronics -- Status: OK 0000
02-Gearbox -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
05-Access/Startup Report -- Status: OK 0000
06-Passenger seat adjustment -- Status: OK.
08-Climate control/heating unit -- Status: OK 0000
09-Central Electrical System -- Status: OK.
Parking Assist 10 -- Status: OK 0000
13-meter distance rule -- Status: Error 0010.
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
18-Heater -- Status: OK 0000
19-pin diagnostic interface -- Status: Error 0010.
High Beam Assist -- Status: OK 0000
28-Heating/Climate: Current status: OK.
34-Level regulation -- Status: Error 0010.
36-seat adjustable passenger seat -- Status: OK 0000.
3B Sensor Electronics -- Status: OK 0000
3C Lane Change -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
46-Comfort System -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
53-Parking brake -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
5F-Information Selection. I -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
6C Rear-view camera -- Status: OK 0000
6D tailgate -- Status: OK 0000
6F Comfort System II -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
81-Selector lever -- Status: OK 0000
85-Camera Controller -- Status: OK 0000
88-Multicontour driver's seat -- Status: OK 0000
Front passenger seat with 89 multi-contour settings -- Status: OK.
8B Distance Rule 2 -- Status: OK 0000
8E-Image processing -- Status: OK 0000
Left-side 8F seatbelt pretensioner -- Status: OK.
90-degree belt tensioner, right side -- Status: OK.
Address 01: Engine Control Module (J623-CDTA)
Label file: None.
Part number SW: 4H0 907 401
Part number HW: 4G0 907 401
Component: 3.0TDI EDC17 H37 0004.
Revision: 53H37---
Encoding: 4A2A401A056601020000
Operating number: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TDI0114H0907401 001010
ROD: EV_ECM30TDI0114H0907401.rod
VCID: E1C29BE0F0556E16743-80B4
No error codes found.
Readiness: 0 0 0 0 0
Address 02: Transmission (J217)
Label file: RKS\0BK-927-156.clb
Part number SW: 4H1 927 158 AA, HW: 0BK 927 156 L.
Component: 0BK 30 TDIRdW H08 0002
Revision: --H08---
Encoding: 001111
ASAM Dataset: EV_TCMALX51011 001013
ROD: EV_TCMALX51011_AU64.rod
VCID: 6FE66DD8B6814866727-803A
Address 03: Brake Electronics (J104)
Label file: 4H0-907-379.clb
Part number SW: 4H0 907 379 C. Part number HW: 4H0 907 379 C.
Part: ESP PREMIUM H10 0273
Revision: -------- Serial Number: --------------
Encoding: 60E5A30006A7C500E300
ASAM Dataset: EV_ESPPremi 005006
ROD: EV_ESPPremi_AU64.rod
VCID: 3260A4AC6533258E5D9-8067
Address 05: Access/Start Authorization (J393)
Label file: RKS\8K0-907-064-05.clb
Part number SW: 4H0 907 064 AA. Part number HW: 4H0 907 064 AA.
Component: BCM2 2.0 H23 0217
Revision: 00002001
Encoding: 01A73000000000000000
VCID: 68D406C49B6F9F5E33D-803D
Subsystem 2 - Part number SW: 4H0 905 852 B, HW: 4H0 905 852 B.
Component: J764 ELV MLB H38 0044
Address 06: Front Seat Adjustment (J521)
Label file: None
Part number SW: 4H0 959 760 D, Part number HW: 4H0 959 760 D.
Component: MEM-BFS H08 0153
Revision: AA000000 Serial Number: 00001002248988
Encoding: 0018320000047201000001010101112131313333283333
Operating number: WSC 02313 785 00200
VCID: 346CA2B497272BBE4F5-8061
Address 08: Climate Control/Heating Unit (J255)
Label file: RKS\4G0-820-043.clb
Part number SW: 4H0 820 043 D, Part number HW: 4H0 820 043 D.
Component: Climate control, 4 zones, H14 0061.
Encoding: 361100BE0C
ASAM Dataset: EV_AirCondiFront 001050
ROD: EV_AirCondiFront_AU64.rod
VCID: 21425BE030D5AE16B43-8074
Address 09: Central Electronics (J519)
Label file: 4H0-907-063.clb
Part number SW: 4H0 907 063 G, Part number HW: 4H0 907 063 G.
Component: BCM1 2.0, H12 0092.
Revision: 11012002 Serial number: 00000000889880
Encoding: 0907201009749FE18B810007A0001800009CC3080E000101800108542F00
VCID: 2C5CBAD44F17737E175-8079
Subsystem 1 - Part number SW: 4H1 955 119 C, HW: 4H1 955 119 A, Label file: RKS\1KX-955-119.CLB.
Component: WWS641 110107 H32 0040
Encoding: 0045F7
Subsystem 2 - Part number SW: 8K0 955 559 C, HW: 8K0 955 559 C, Label file: RKS\8K0-955-559.CLB.
Component: RLS H04 0003.
Encoding: 025523
Subsystem 3 - Part number SW: 4H0 941 531 B, HW: 4H0 941 531 B.
Component: E1 - LDS H07 0044.
Subsystem 4 - Part number SW: 4H0 907 472 A, HW: 4H0 907 472 A.
Component: A31 LED Mod1L H01 0006
Encoding: 100000
Subsystem 5 - Part number SW: 4H0 907 472 A, HW: 4H0 907 472 A.
Component: A27 LED Mod1R H01 0006
Encoding: 100000
Subsystem 6 - Part number SW: 4H0 907 705 J, HW: 4H0 907 705 C.
Component: EVLS-SG H08 0280.
Encoding: 020300
Subsystem 7 - Part number SW: 4H0 907 658, HW: 4H0 907 658.
Component: AQ_Hum_Sensor H02 0002
Address 10: Parking Assist 2 (J446) Label file: RKS\4H0-919-475-7X2.clb
Part number SW: 4H0 919 475 H, HW: 4H0 919 475 C.
Component: PARKING ASSIST ACC H07 0030
Revision: 11001001 Serial number: 55931101200720
Encoding: 300B02
ASAM Dataset: EV_EPHVA18AU57X0000 001002
ROD: EV_EPHVA18AU57X0000.rod
VCID: 377695B88E51C0A66A7-8062
Address 13: Distance Control (J428)
Label file: RKS\4H0-907-561.clb
Part number SW: 4H0 907 561 A
Part number HW: 4H0 907 561
Component: ACC3 H15 0160
Serial number: 00000000000000
Encoding: 3E04010201
ASAM Dataset: EV_AdaptCruisContrAU64X 001012
ROD: EV_AdaptCruisContrAU64X.rod
VCID: 295243C048E56656EC3-807C
"One error found:"
10240 - Sensor for automatic distance control.
C110B F0 [008] - Limited visibility.
Sporadically - confirmed - checked since last deletion.
Address 15: Airbag (J234)
Label file: RKS\4H0-959-655.clb
Part number SW: 4H0 959 655 C, Part number HW: 4H0 959 655 C.
Part: Airbag
10.43 H40 0040
Revision: -------- Serial Number: 003JG001CA7P
Encoding: 30314246323430303031554A304C34483053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
VCID: 366898BC895B39AE711-8063
Crash sensor for driver-side side airbag:
Serial number: 3575HRB404T0C15IF0RI
Crash sensor for side airbag, passenger side.
Serial number: 3585HRB404T0C15I8HRT
Rear side airbag crash sensor (driver's side).
Serial number: 3515JRB405P060GKM0TQ
Crash sensor for rear side airbag, passenger side.
Serial number: 3525JRB405P060GK61G
Crash sensor for front airbag, driver's side:
Serial number: 3554VRB4059060GK39G2.
Crash sensor for front airbag, passenger side.
Serial number: 3564VRB405B060GK6OSZ
Address 16: Steering wheel electronics (J527)
Label file: None.
Part number SW: 4H0 953 568 A, Part number HW: 4H0 953 568 A.
Component: Steering module H08 0007.
Revision: -------- Serial Number: 90815JLH0002L
Encoding: 00003C
VCID: 3162ABA068351E96243-8064
Subsystem 1 - Part number SW: 4H0 951 528 A, HW: 4H0 951 528 A.
Component: E221 - MFL H06 0009
Address 17: Control unit (J285)
Label file: RKS\4H0-920-xxx-17.clb
Part number SW: 4H0 920 930 D, Part number HW: 4H0 920 930 F.
Component: TDieRDWACC--- H30 0297
Revision: 26110011 Serial number: 658070111593044
Encoding: 1386080017040008000000
ASAM Dataset: EV_RBD4K 004033
ROD: EV_RBD4K.rod
VCID: 275645F85EF15026FA7-8072
Analog clock:
Subsystem 1 - Part number SW: 4H0 919 204 G, HW: 4H0 919 204 G.
Component: Analog clock D4 H04 0210.
Serial number: 1101221000251
Address 18: Auxiliary heater (J364)
Label file: RKS\8R0-265-105.clb
Part number SW: 4H0 265 105 A
Part number HW: 4H0 265 105 A
Component: Stand heater, part number H22 0240.
Revision: 56005006 Serial number: 20110106211635
Encoding: 5D1300
VCID: 20445EE433DFA71EBBD-8075
Address 19: Diagnostic interface (J533)
Label file: None.
Part number SW: 4H0 907 468 E, Part number HW: 4H0 907 468 C.
Component: J533 -- Gateway H08 0204
Revision: -------- Serial Number: 00000000079166
Encoding: 00CD077D00
ASAM Dataset: EV_GatewUDS 001025
ROD: EV_GatewUDS_AU57.rod
VCID: 336EA1A89A292C8656F-8066
Battery monitoring control unit:
Subsystem 1 - Part number SW: 4H0 915 181, HW: 4H0 915 181.
Component: J367-BDM H07 0140
Serial number: 00000000005650454534
Voltage stabilizer:
"One error found:"
4224 - Engine Control Unit (ECU)
U0100 00 [008] - No communication.
Freeze Frame:
Error status: 00000001
Error priority: 2
Error frequency: 1.
Lost Count: 241
Mileage: 57581 km
Date: 2014.11.14
Time: 12:36:00
Address 20: High Beam Assist (J844)
Label file: RKS\8K0-857-511.clb
Part number SW: 8K0 857 511 E, Part number HW: 8K0 857 511 E.
Component: FLA H04 0004
Revision: AA001002
Encoding: 04018B6B74745D545420363E
VCID: 336EA1A892292C8656F-8066
Address 28: Heating/Climate control (E265)
Label file: None.
Part number SW: 4H0 919 158 D, Part number HW: 4H0 919 158 D.
Component: Climate control vent, rear. Part number: H14 0062.
Encoding: 0100000000
ASAM Dataset: EV_AirCondiHeck 001039
ROD: EV_AirCondiHeck_AU64.rod
VCID: 3162ABA060351E96243-8064
Address 34: Level Control (J197)
Label file: Bypass due to failure!
Part number SW: 4H0 907 553 C, Part number HW: 4H0 907 553.
Component: AIR DAMPER H17 0096
Encoding: 008002
ASAM Dataset: EV_AirSuspe 003022
ROD: EV_AirSuspe_AU64.rod
VCID: 2C5CBAD44717737E175-8079
"One error found:"
403200 - Function disabled.
C10C8 00 [008] - -
Freeze Frame:
Error priority: 6
Error frequency: 1.
Lost Count: 245
Mileage: 58,006 km
Date: 2014.11.17
Time: 18:21:19
Address 36: Seat adjustment for driver (J136)
Label file: None.
Component: MEM-FS H08 0153
Revision: AA000000 Serial Number: 00001002248986
Encoding: 0018330000057201000001010101112131313333203333
Address 3B: Sensor electronics (J849)
Label file: None.
Part number SW: 4H0 907 637 Part number HW: 4H0 907 637
Component: SARA 6D, Part Number: H02 0015.
Revision: -------- Serial Number: EJ1BPA31009U2$0
Operating Number: WSC 00000 000 00000
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA.rod
VCID: ECDCFAD40797337ED75-80B9
Address 3C: Lane Change
Label file: RKS\4H0-907-566.clb
Part number SW: 4H0 907 566 Part number HW: 4H0 907 566
Component: J769 SWA MasterH02 0100
Revision: 00H02000 Serial Number: 6PZ 010 287-00
Encoding: 0000101
Operating number: WSC 27154 123 106547
VCID: EDDAF7D0F48D3A76C0B-80B8
Subsystem 1 - Part number: 4H0 907 568.
Component: J770 SWA Slave H01 0100
Subsystem 2 - Serial number: 6PZ 010 287-20.
Subsystem 3 - Serial Number: 5F23.11.1000H010003CH11958.
Subsystem 4 - Serial number: H11958.
Address 42: Door Electric Driver (J386) Label file: None.
Part number SW: 4H0 959 793 E, Part number HW: 4H0 959 793 E.
Component: TSG FA, H02 0162.
Revision: -------- Serial Number: 0000111848756
Encoding: 011F02215E00628202080003
Operating number: WSC 02312 785 00200
VCID: 3B7E8988BA79E4C68EF-806E
Address 46: Comfort System (J393)
Label file: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0141169355
Encoding: 011A062000B93484B3A0C7C40E0100000000000000000000000000000000
Subsystem 1 - Part number: 4H0 951 177.
Component: DWA sensor H01 0010.
Subsystem 2 - Part number: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501.
Subsystem 3 - Part number SW: 4H0 959 591, HW: 4H0 959 591.
Component: J245 PS50.028 H06 0006
Encoding: 001F00
Subsystem 4 - Part number SW: 4H0 947 135 G, HW: 4H0 947 135 G.
Component: Roof electronics H11 0080.
Encoding: 010000
Subsystem 5 - Part number SW: 4H0 959 591 A, HW: 4H0 959 591 A.
Part number: V252 PS009 H05 0004.
Address 47: Soundsystem (J525)
Label file: None.
Part number SW: 4G0 035 223 A, Hardware: 4G0 035 223 A.
Component: BOSE G3 C7 H07 0070
Revision: CJ007000 Serial number: 00000000015306
VCID: 1B3E69081AB984C66EF-804E
Address 52: Door electronics, passenger side (J387) Label file: None.
Part number SW: 4H0 959 792 F. Part number HW: 4H0 959 792 F.
Component: TSG BF H07 0162
Revision: -------- Serial Number: 0000111781941
Address 53: Parking brake (----)
Label file: RKS\4H0-907-801.clb
Part number SW: 4H0 907 801 D, HW: 4H0 907 801 A.
Component: EPB-4 H03 0010
Revision: -------- Serial Number: 00000000031481
ASAM Dataset: EV_ParkBrake 001021
ROD: EV_ParkiBrake_AU48.rod
Address 56: Radio (R) Label file: None.
Part number SW: 4H0 035 053 Part number HW: 4H0 035 053
Component: Radio U Basic H52 0050.
Revision: AB001007 Serial Number: 438AO0B7510063
Encoding: 010003010000000001
VCID: DCBCAA14DF3743FE275-8089
Address 57: TV Tuner (R78)
Label file: RKS\4F0-919-129.clb
Part number SW: 4F0 919 129 E
Hardware number: 4F0 919 129
Component: HybridTV-DVB H07 0520
Revision: R0070000 Serial number: 76301301270001
Encoding: 01010000
VCID: 2E58B0DC790B016E391-807B
Address 5F: Information Selection. I (J794)
Label file: RKS\4E0-035-6xx-5F.clb
Part number SW: 4H0 035 670 F, Part number HW: 4H0 035 670 C.
Component: H-BNT-EU H41 0239
Revision: -------- Serial Number: 060LX0A7503419
Encoding: 020100000001FBEF75308B1E000000030800010000000000
VCID: 275645F856F15026FA7-8072
Subsystem 1 - Part number: 8R0 060 884 N
Component: EUR 2011 1205
Subsystem 2 - Part number SW: 4H0 919 604 C, HW: 4H0 919 604 C.
Component: DU8 D4 SV NB H46 0021
Subsystem 3 - Part number SW: 4H1 919 600 D, HW: 4H1 919 600.
Component: E380 BDT D4 H09 0063
Subsystem 4 - Part number: 8R0 060 961 A
Component: CD Database 2712.
Address 62: Door electric strike, left/right (J388)
Label file: None
Part number SW: 4H0 959 795 B. Part number HW: 4H0 959 795 B.
Component: TSG HL H09 0162
Revision: -------- Serial Number: 0000110760645
Encoding: 010F02214000628202080003
VCID: 3A708C8CB543DDCE959-806F
Address 6C: Rear view camera
Label file: 4H0-907-441.clb
Part number SW: 4H0 907 441 Part number HW: 4H0 907 441
Component: SG Reverse Camera 0030.
Revision: --H04--- Serial Number: 525 PA8J0YD128
Encoding: 1020002
VCID: E5CA8FF02C7D023688B-80B0
Address 6D: Rear door (----)
Label file: RKS\4H0-959-107.clb
Part number SW: 4H0 959 107 P, HW: 4H0 959 107 M.
Component: HDSG Module H11 0036
Revision: 10011001 Serial Number: 354000006
Encoding: 0210044000
ASAM Dataset: EV_DeckLidContrUnit 001025
ROD: EV_DeckLidContrUnit.rod
VCID: 3B7E8988B279E4C68EF-806E
Address 6F: Comfort System II (J773)
Label file: None
Part number SW: 4H0 907 412 Part number HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial Number: 000000020764
Encoding: 200000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: E3CE91E8EA497C0666F-80B6
Address 72: Door electrical contact, high, right (J389)
Label file: None.
Component: TSG HR H09 0162
Revision: -------- Serial Number: 0000109342136
Address 81: Selector lever (J587)
Label file: None.
Part number SW: 4H1 927 731 A, Part number HW: 4H1 927 731 A.
Component: GSM-LL H05 0081
Revision: 0L0D5012 Serial Number: SN101213 0224
ASAM Dataset: EV_GSM2x3Mono 001014
ROD: EV_GSM2x3Mono.rod
VCID: 2B5EB9C8421974461EF-807E
Address 85: Camera Control Module (J852)
Label file: None.
Part number SW: 4G0 907 217
Part number HW: 4H0 907 217 A
Component: DPC-SG H24 0034
Revision: -------- Serial Number: 262130025421000
Encoding: E8060000
ASAM Dataset: EV_OnBoardCameraDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: E5CA8FF0E47D023688B-80B0
Address 88: Multi-contour driver's seat (J873)
Label file: None.
Part number SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00456606099802.
Encoding: 662FF2
ASAM Dataset: EV_IVBDriveSideFrnt 001003
ROD: EV_IVBDriveSideFront.rod
VCID: 2F66ADD876010866327-807A
Address 89: Multi-contour passenger seat (J872)
Label file: None.
Serial number: 00456606098002
Encoding: 262FF2
ASAM Dataset: EV_IVBPasseSideFrnt 001003
Address 8B: Distance Control 2 (J428)
Part number SW: 4H0 907 541 A
Part number HW: 4H0 907 541 A
ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
ROD: EV_AdaptCruisContr2AU57X.rod
Address 8E: Image Processing (J851)
Label file: 4G0-907-107.clb
Part number SW: 4G0 907 107 B, HW: 4H0 907 107
Component: BV-SG H28 0034
Serial number: 000040181712107
Encoding: 01A0BB001111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
VCID: 254A4FF024FD4236C8B-8070
Address 8F: Left seat belt pretensioner (J854)
Label file: 4H0-980-94x-RGS.clb
Part number SW: 4H0 980 945
Part number HW: 4H0 980 945
Component: RGS-VL H05 0070
Encoding: 0066F609031F037E070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: EFE6EDD83681C866F27-80BA
Address 90: Seat belt pretensioner, right (J855)
Part number SW: 4H0 980 946
Part number HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: F0E4EEA42BBFD79EEBD-80A5
End.
Audi A4 AKE
Translated on 02-10-2026, 21:18.
Hans Dampf
2013 Ford Galaxy
Post25-11-2014, 12:05    Subject: Problem Solved: Quick Fixes & Solutions Quote
Hello, please disregard the question I asked earlier. I have found a solution to the problem.
While the vehicle has these small rectangular pieces in all the door handles that resemble a locking mechanism, they are merely decorative and do not contain any antennas.
The vehicle was delivered as standard without the Advanced Key system. The production code 4K4 = "Central locking with remote control."
Sincerely,
Audi A4 AKE
Post25-11-2014, 12:21    Subject: Audi A8 Advanced Key: Do you have it? Programming? Quote
icon_biggrin.gif Thank you for the feedback. The information that the vehicle may also have been delivered with a "dummy" part is certainly helpful for some people. icon_wink.gif
Translated on 02-10-2026, 21:19.
Post25-11-2014, 17:59    Subject: Audi A8 Advanced Key: Do you have it? Programming? Quote
Hi.
Haven't all (at least the higher-end) Audis had those rectangular designs for a few years now?
With the 4G model, you can identify Keyless entry by the chrome trim pieces on the door handles.
However, this only applies if the "black gloss package" is not installed.
Translated on 02-10-2026, 21:20.
Hans Dampf
2013 Ford Galaxy
Post26-11-2014, 13:28    Subject: Audi A8 Advanced Key: Do you have it? Programming? Quote
Unfortunately, I don't know that.
I have to unlock the car using the remote control and then put the key in my pocket or somewhere in the car. When I park the car, I then have to dig out the key again to lock it.
The person who ordered the vehicle probably didn't trust the technology (or didn't know what it was), which I find illogical, considering that Audi offers this configuration.
But unfortunately, that's the situation now, and retrofitting is unrealistic.
Audi A4 AKE
Post27-11-2014, 10:29    Subject: Audi A8 Advanced Key: Do you have it? Programming? Quote
That's been the standard equipment for the A6 since 2012, i.e., since the 4G/C7 generation.
The engine starts keylessly, but the doors don't unlock.
Therefore, the most important thing is the cup holder, where the key is placed during the drive.
Complete nonsense.
Translated on 02-10-2026, 21:22.
Hans Dampf
2013 Ford Galaxy
Post27-11-2014, 11:20    Subject: Audi A8 Advanced Key: Do you have it? Programming? Quote
Yesterday, I checked all the system components and made a list of everything that's missing. I estimated the material cost to be around €900 (including new door handles), assuming I don't need any new keys.
Since the comfort control module and the access authorization module can be reprogrammed, only 4 antennas are needed (two in the rear doors, one in the trunk, and one centrally in the vehicle), along with 4 sensors in the door handles (possibly new door handles). The question remains whether the wiring in the doors is already in place, as well as for the antennas located centrally and in the trunk.
Furthermore, it would be interesting to see a PR code with an Advanced Key for the A8.
Audi A4 AKE
Translated on 02-10-2026, 21:23.
uncelsam
Post27-04-2015, 18:27    Subject: Audi A8 Advanced Key: Do you have it? Programming? Quote
I'm almost finished with the Kessy retrofit on my A6 4G.
You also need a different comfort control unit (46) that also includes the access authorization control unit (05).
You only need two antennas for that, and those are already installed in the trunk and under the MAL (Multi-Access Layer).
Finally, you need to set the appropriate parameters using VCDS.
Greetings.
Translated on 02-10-2026, 21:24.
Post27-04-2015, 20:58    Subject: Audi A8 Advanced Key: Do you have it? Programming? Quote
Greetings
I would be interested to see the finished translation.
"At Audi, things are probably going relatively well due to the partial keyless (keyless start) system. What surprises me is that a new (keyless) comfort control unit can be programmed onto a vehicle that was originally delivered 'with key'."
For the Passat 3C (without any keyless entry system), the problem lies in the fact that the keys are linked to the Vehicle Security System (WFS), and it's not possible to order replacement keys for the vehicle that would function properly with the (key-based) system.
Regarding the antennas, I'm surprised you only mention two external antennas. The Passat has an external antenna in the bumper for the trunk opening (the one inside the trunk is just to prevent accidentally locking the car with the key inside).
Greetings.
Guste.
Translated on 02-10-2026, 21:26.
uncelsam
Post27-04-2015, 21:12    Subject: Audi A8 Advanced Key: Do you have it? Programming? Quote
The pairing process still needs to be done, but according to AKTE, the comfort control unit I purchased is the current replacement for my existing one.
The keys for the 4G models are always compatible with the Kessy system, due to the keyless start function.
The Kessy systems have three or four antennas. The key position is determined by measuring the signal propagation time.
For the A6, you only need two additional antennas, as the other two are already installed by default, resulting in a total of 4.
Greetings.
Translated on 02-10-2026, 21:28.
uncelsam
guste100 likes this.
Post19-05-2015, 22:33    Subject: Audi A8 Advanced Key: Do you have it? Programming? Quote
Here's the feedback I promised: My Kessy is now icon_smile.gif!
After replacing the comfort control unit, I used VCP to upload the correct Kessy parameter set and coded control units 46 and 5 for Kessy.
Subsequently, the system worked immediately.
So, for 4G, you need the following:
Hardware:
4x door sensor.
2 antennas in the rear doors.
Cable harnesses.
Suitable comfort control unit (I have a part number: 4H0 907 064 FB, hardware number: 4H0 907 064 EB).
Software:
Mandatory VCP due to the parameters.
Greetings.
Translated on 02-10-2026, 21:30.
Post20-05-2015, 6:53    Subject: Audi A8 Advanced Key: Do you have it? Programming? Quote
Thank you very much for your detailed feedback!
uncelsam wrote:
After the comfort control unit was replaced, I used VCP to upload the correct Kessy parameter set, and I coded control units 46 and 5 for Kessy.
Sure, I'd be happy to elaborate. I'm new to VCP, and it sounds interesting, but the description of what the tool actually does is quite vague.
In your specific case, I'd be interested to know: Where did you get the quote "suitable Kessy parameter set" from? Does the program provide it directly? Or is it found in some obscure online sources?
Thank you for the explanation!
Greetings.
Guste.
Translated on 02-10-2026, 21:32.
No new posts Keyless Entry Installation Guide by IN.PRO Troubleshooting & Guides
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Recoding the engine control unit On-Board Diagnostics (OBD)
No new posts Advanced MFA: Secure Authentication Solution Electrical Systems, Vehicle Electronics, Multimedia
No new posts Ford S-Max Keyless: Problems & Solutions Electrical Systems, Vehicle Electronics, Multimedia
No new posts Keyless Open for Polo 6R (POC) for Armrests ;) On-Board Diagnostics (OBD)
