Automatic Transmission Fluid Check: How To
Marko
Post26-09-2003, 17:08    Subject: Automatic Transmission Fluid Check: How To Quote
Hi!
According to statements from VW/AUDI, this should be possible via diagnosis.
Does anyone know which channel displays the current water level?
@ Gremlin - I found your older thread using the search function:
/viewtopic.php?t=1431&highlight=automatic transmission
examined.
How far have you gotten with tracking down this setting? I'd be interested to know...
cu: Marko
Lieber TDI statt lahme Ente!
-A6 4B2 2.5 TDI AYM-
Translated on 03-10-2026, 21:43.
Steve
Post26-09-2003, 17:29    Subject: Automatic Transmission Fluid Check: How To Quote
Hello...
I haven't encountered that before.
While a diagnostic device is needed, it's only to measure the oil temperature.
To be tested, as the temperature is only 40-45°C (which I believe to be the case).
leads to the correct result.
Best regards, Steve.
Translated on 03-10-2026, 21:44.
No new posts Automatic Transmission Problems: Audi A4 01N AFN General Tips
No new posts Doku Golf 5, Problems with windshield washer/water system Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Gear Jerk: T4 Problems & Solutions Diesel Engine Technology
No new posts Automatic malfunction Diesel Engine Technology
No new posts Automatic Transmission Problems Diesel Engine Technology
No new posts Whistles 1Z + Automatic Transmission, Chassis, Body & Interior
