guste100 wrote: |
ulf wrote: | | In an AC system, the evaporator could freeze if the "cold" is not removed. |
Hi!
Here's another way to put it:
If the refrigerant in the evaporator does not evaporate and instead enters the compressor in liquid form, the compressor is damaged.
Practical tip:
If the air conditioning isn't cooling well, check the dryer vent.
If it has a hot and a cold side, it should be replaced.
