Can automatic central locking be disabled? Audi A6 4B
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Pölscheich
Post21-05-2015, 8:06    Subject: Can automatic central locking be disabled? Audi A6 4B Quote
Hi everyone.
Is it fundamentally possible to disable the automatic locking feature on an Audi A6 4B (C5 model year 2002)?
After a short time (approximately 30 seconds), the car will automatically lock again if it was opened remotely and the driver's door is not then opened. It can be really annoying when, for example, you open the back door, put your bag and keys inside, close the door, and then walk to the driver's side... (I wonder where I learned that).
I would like to disable this function. Can it be done individually?
I would like to keep the other functions of the central locking system, such as the remote closing feature.
Back to top Profile PM Email
Post21-05-2015, 8:27    Subject: Can automatic central locking be disabled? Audi A6 4B Quote
You can't disable it; simply repair the corresponding door lock, and the problem won't happen again. icon_wink.gif
Pölscheich
Post21-05-2015, 8:33    Subject: Can automatic central locking be disabled? Audi A6 4B Quote
Hi.
"Thank you, I had already suspected that based on my own research. I haven't been able to find anything that quite fits the bill."
Looks like it's time to fix some locks...
Thank you and greetings.
Post21-05-2015, 9:03    Subject: Can automatic central locking be disabled? Audi A6 4B Quote
First, we need to determine who is affected... then, perhaps we can just repair that one (the one on the left rear).
Post21-05-2015, 10:51    Subject: Can automatic central locking be disabled? Audi A6 4B Quote
matthiasTDI96 wrote:
First, we need to determine who is affected....
Here's a simple tip for testing: If a door doesn't turn on the interior light, it also won't prevent the door from being locked again.
KANE326
Post25-07-2015, 21:32    Subject: Can automatic central locking be disabled? Audi A6 4B Quote
When I open the rear door, only the reading light in the front turns on, but not the one in the back. Is that normal?
All the door locks are new.
Wiesel
Post25-07-2015, 22:09    Subject: Can automatic central locking be disabled? Audi A6 4B Quote
KANE326 wrote:
When I open the rear door, only the reading light in the front turns on, but not in the back. Is that normal?
All door locks are new.
Does your Octavia do the same thing? It might be normal behavior.
No new posts Automatic transmission 01M.J - Identification codes and e... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic transmission 01M.C: Identification and error codes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts SEAT Arosa: Disable Automatic Door Lock On-Board Diagnostics (OBD)
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
No new posts FIS in the Audi Transmission, Chassis, Body & Interior
No new posts Audi A8 4.0 TDI Diesel Engine Technology
