KANE326 Schrauber
13-07-2015, 7:56 Subject: |
HI,
"B 10240" is indicated on all control units with which I have communication.
The parking assist, climate control, and central locking systems are not communicating with me via the K-Line.
Joined: 04/12/2002 Posts: 18086 Karma: +797 / -0 Location: St.Gallen 2018 Volkswagen T6
13-07-2015, 11:23 Subject: |
You have a private message.
Profile PM WWW Garage |
KANE326 Schrauber
19-07-2015, 22:36 Subject: |
So... it seems like the second K-line is "out of order." Because I can't access any of the control units there.
"On the 2003 C5, it's set to 'K2'."
Navigation system, radio, multifunction steering wheel, parking assist, central locking, tire pressure monitoring system, air conditioning, automatic headlight range control.
I will check a few K-Lines tomorrow to see if they are working properly  .
KANE326 Schrauber
21-07-2015, 18:56 Subject: |
Update.
After disconnecting the LPG control unit from the K-K line, the diagnosis of the K1 line also works without the engine running, but with the ignition on. However, the K2 management still refuses.
Since the central locking control unit  is already doing whatever it wants (the interior lights sometimes turn on, sometimes not when the door is open, the remote central locking no longer works), it's time to replace it.
I'll report back.
DieselBär30x Profi-Schrauber
Joined: 01/17/2008 Posts: 3560 Karma: +101 / -0 Location: MĂźnchen & Passau
21-07-2015, 19:07 Subject: |
Hey Kanne!
KANE326 wrote: | | ... does whatever it wants, (interior lights turn on and off randomly when the door is opened, ... |
Please check the microswitches in the door locks  .
Don't exchange the StG for nothing.
Best regards from Munich! 1. S.verlängerung: Audi A4 Avant quattro, 1,9 TDi MKB: AFN, BJ98, Vollausstattung, +VP1L
3. T5 1,9 TDI PD (AXC), BJ04 - nur Ărger!
21-07-2015, 20:00 Subject: |
@ KANE326 : Could you please remember some of the values I mentioned? Because otherwise, I can't assess whether the proposed action makes sense or not.
KANE326 Schrauber
21-07-2015, 20:13 Subject: |
All door locks are new  .
KANE326 Schrauber
25-07-2015, 18:02 Subject: |
Nothing is working anymore. Neither with the engine running, nor with just the ignition on.
With the new central control unit, at least the interior lighting responds when the unit is queried; it briefly flashes, but the control unit still doesn't provide a response.
I can't access any control units. Not even a motor  .
KANE326 Schrauber
27-07-2015, 15:14 Subject: |
Okay, so I just went to Audi/VW... and they also said that it's not on any of the control units in the K2 line. Speaking: We tested the ZV (central ventilation) and climate control systems. "Not available."
Now, I could potentially rewire the K-line from the central locking control unit and connect it directly.
