Touran: Klimaanlage kühlt nicht | Posts 16+
Go to page: Previous  1, 2
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post27-07-2015, 16:13    Subject: Quote
@T3SurferViewing profile: T3Surfer:
Is there a way to test this while it's still installed? Or, in other words, can I test it without opening the system?
a) "bridge" and set the compressor to maximum power.
b) Can I change it without emptying the refrigerant?
Translated on 09-08-2026, 16:40.
Post27-07-2015, 21:56    Subject: Quote
There are even testing devices to test the control valve! But it requires some brainpower.
If there's a cable break or something like that, there would be an error in the memory! (Try unplugging the compressor - you'll immediately see an error in the memory!)
Very often, there is no fault; provided that there is sufficient refrigerant!
Your climate control is only cooling very slightly due to a faulty regulating valve, which means: the compressor is working properly! It would be different if the evaporator temperature were as warm as the intake air; then there would be a refrigerant leak or the compressor's safety torque coupling has disengaged. You can see this when the engine is running and using a dental mirror – the inner disc will not rotate.
To replace the pressure relief valve, refrigerant must be evacuated.
Translated on 09-08-2026, 16:42.
StreifLicht
Post01-08-2015, 10:49    Subject: Quote
Hello T3Surfer,
That makes sense.
I once measured the PWM signal. It seems to be correct. It's at 500 Hz with varying amplitude levels, depending on the control method.
Please provide the German text you would like me to translate into English.
Here's the translation:
"What exactly does a control valve do? Is that different from controlling the compressor's swashplate? And does my Touran even have its swashplate controlled?"
 Klima-Ansteuersignal, Drehschalter auf 100% kalt.
 File size:  67.37 KB
 Viewed:  2506 times
 Klima-Ansteuersignal, Drehschalter auf 25% kalt.
 File size:  67.53 KB
 Viewed:  2527 times
Translated on 09-08-2026, 16:44.
No new posts A3 Climate Control Not Working: Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3C air conditioning not cooling General Tips
No new posts Touran GRA not working after TCU replacement Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AC Not Cooling? Troubleshooting & Repair Tips. Transmission, Chassis, Body & Interior
No new posts Air conditioner not cooling during speed fluctuations Transmission, Chassis, Body & Interior
No new posts Touran AC Not Working: Troubleshooting & Repair Data Diesel Engine Technology
No new posts Air conditioner not cooling - Year of manufacture 2000, c... Transmission, Chassis, Body & Interior
