Control panel input not responding, possible faulty diagnostic system?
mcgregg
Karma: +7 / -1   Thank you, like it!
Post15-08-2015, 11:17    Subject: Control panel input not responding, possible faulty diagnostic system? Quote
Hello everyone!
Yes, I have used the search. After 1.5 hours of Googling, I've come to the conclusion that it's okay to ask what I probably seem like stupid questions. icon_redface.gif icon_wink.gif
I have VCDS 14.10 (purchased previously and now freshly updated) and I want to reset the service interval display on my Octavia 2, built in 2005, with engine code BKD. However, I get the message "Central electrical system does not respond". During the connection test, I receive the message that my interface (the connection cable to the purple diagnostic connector?) Ross-Tech Key-USB Version 3.01 (purchased here in 2006) is fine, but
does not support the CAN bus. I suspect it's because of this. Therefore, I need a new one. What should I pay attention to now? I couldn't find anything I wanted in the shop.
Ah, so, the Octavia 1 (MJ 2001) always worked, but it probably didn't have a CAN bus either.
Greetings
mcGregg
Skoda Octavia II Combi TDI, 2012, 103kW/140PS MKB CFHC
Post15-08-2015, 11:25    Subject: Control panel input not responding, possible faulty diagnostic system? Quote
VCDS OBD2 Pro Diagnose KKL CAN P-46
mcgregg
Post15-08-2015, 18:33    Subject: Control panel input not responding, possible faulty diagnostic system? Quote
Hello Michael!
Thank you for your quick response. 369 € seems a bit expensive to me, especially since I already have VCDS. Surely there must be a more affordable solution. icon_wink.gif
Greetings
mcGregg
Post15-08-2015, 21:32    Subject: Control panel input not responding, possible faulty diagnostic system? Quote
VCDS Diagnostic System MicroCAN p-221
It's also possible for 100€ less, but I don't think it's particularly sensible in the long run. Because, for example, if you buy an Audi A4 or A6 in a few years, you won't be able to use it then.
Furthermore, the €369 is a joke when you consider what similar products cost from other manufacturers (BMW, MB...). icon_wink.gif
No new posts DPF not regenerating Troubleshooting & Guides
No new posts 2.7l V6 CR-TDI, Anpassungskanäle funktionieren nicht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1Z No Response: Troubleshooting & Solutions On-Board Diagnostics (OBD)
No new posts Anhängersteuergerät antwortet nicht On-Board Diagnostics (OBD)
No new posts Control Unit Not Responding: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Battery management not responding? Electrical Systems, Vehicle Electronics, Multimedia
