Golf 6 Plus - Air conditioning compressor "making a noise"
Post15-08-2015, 11:02    Subject: Golf 6 Plus - Air conditioning compressor "making a noise" Quote
I have a G6+ 1.4 TSI (CAXA) with DSG 55,000 km, almost 5 years old, which sometimes makes a noise with the air conditioning compressor.
It's then a speed-dependent running noise that, if present, can be immediately stopped by simply pressing "AC off". Sometimes, it can also be provoked by "AC on".
But it is not always present. After discovering this, I already had my own problems, and now I'm struggling to get it back on track.
Outside, near the engine, the engine noise is louder, and you can actually only hear it inside the car.
Now that "Service now" and the HU (roadworthiness test) are due in September:
Should I gamble on a goodwill repair and get it done by VW, or have everything done at the independent workshop that is scheduled for September and is considered "more capable"?
Dear, please get back to me soon, as the compressor is always running?
Feeling overwhelmed by the overall situation; m
P.S.
The groaning also occurs rhythmically, approximately 2 times per second, when the compressor is turned off.
EDIT FILM
Scenario:
Vehicle is parked
On foot, approximately 2000 rpm - because it was clearly visible while driving.
Turn on/off climate, as shown
To hear:
Rhythm at 0:36
then, in idle mode, "pleasant" warehouse noise
Direct link to the video:
/download.php?id=9751
Golf 6 Plus - Air conditioning compressor "making a noise" - Golf_6_plus_Klima.mp4
 Geräusche Klimaanlage Golf 6
 File size:  4.28 MB
 Viewed:  1817 times
Post15-08-2015, 13:14    Subject: Golf 6 Plus - Air conditioning compressor "making a noise" Quote
Could it be that the noise is "only" coming from the pulley?
This has minimal play on the rest of the otherwise smooth-running and clean-moving mechanism.
Video
/download.php?id=9752
Golf 6 Plus - Air conditioning compressor "making a noise" - Denso_Klima_Scheibe.mp4
 Spiel Riemenscheibe Klimakompressor Golf 6
 File size:  246 KB
 Viewed:  2385 times
Post15-08-2015, 14:45    Subject: Golf 6 Plus - Air conditioning compressor "making a noise" Quote
Hello Martin,
I've never seen anything like this before. Have you ever checked if any of the air conditioning system's hoses are vibrating/wobbling and hitting the bodywork when "Compressor on"?
Best regards, Rainer
Post16-08-2015, 11:43    Subject: Golf 6 Plus - Air conditioning compressor "making a noise" Quote
The vibration was also a good idea.
But underneath (the helper turned the climate control on/off), I couldn't see anything.
You can also clearly hear the growling/groaning if you don't use a wrench as an extension between your ear and the compressor.
Especially the sound when you turn the air conditioning OFF... like a relieved "Ahhhhhh".
"It somehow fits with 'lager damage'... and thus a new compressor icon_sad.gif (after only 5 years and 55,000 km)"
Post16-08-2015, 12:29    Subject: Golf 6 Plus - Air conditioning compressor "making a noise" Quote
I also had similar noises when turning off the air conditioning in my A3 8L: This was due to the expansion valve.
brezelmann01
Post16-08-2015, 12:54    Subject: Golf 6 Plus - Air conditioning compressor "making a noise" Quote
I am unfortunately unable to play the videos/sounds. However, I know that there have been extremely high rates of failures and supplier changes specifically with the A3, particularly with some older compressor models.
gnasch
Karma: +23 / -0   Thank you, like it!
Post17-08-2015, 21:26    Subject: Videos and Audio Quote
Sorry if I'm interrupting, but I'm just seeing large grey fields in the browser for the videos and sounds.
I suspect that Adobe Flash is being used here, which I, however, do not install due to security concerns. Above the gray fields, there is a filename.
Is it possible to simply download these files using my own means and then play them myself?
Thank you and please forgive me for the off-topic comment....
gnasch
Familienautos: 1988 Golf GTD mit 51 kW MKB MF -- 2008 Touran 1T2T54 T D7F LKF LA7W CN 77kW BLS
Post17-08-2015, 23:53    Subject: Golf 6 Plus - Air conditioning compressor "making a noise" Quote
Hello Gnasch,
yes, that is: www.videolan.org
HTML5 Audio/Video Playback is still under development.
Post18-08-2015, 13:25    Subject: Golf 6 Plus - Air conditioning compressor "making a noise" Quote
Rainer,
The problem is that you can't access the files as a guest user.
I've also added direct links, so that everyone can easily load and watch the videos.
Post18-08-2015, 13:40    Subject: Golf 6 Plus - Air conditioning compressor "making a noise" Quote
Translated on 18-07-2026, 18:32.
gnasch
Post18-08-2015, 21:26    Subject: Direct links Quote
These direct links are brilliant:
Now, when I open it, I use: vlc
and it displays them immediately.
That's convenience; who needs direct playback anymore?
Thank you and best regards,
gnasch
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4: Right Front Inner Fender Liner Transmission, Chassis, Body & Interior
No new posts TDI "Wiring Issues": Golf 3 Engine Control Problem? On-Board Diagnostics (OBD)
No new posts Golf Roof Antenna: Drill & Installation Dimensions Transmission, Chassis, Body & Interior
