Golf IV, 90 PS TDI BJ 2002 Gas hängt | Posts 16+
Go to page: Previous  1, 2
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
Karma: +1344 / -0   Thank you, like it!
Post09-10-2015, 19:23    Subject: Quote
The question would have been more appropriate here.
You can usually find out most of the measurement values by experimenting with the measurement blocks.
For the specific vehicle/engine type, it is recommended to use the "injection and glow plug system" diagnostic tool, which can be purchased online from Volkswagen for a reasonable price.
https://erwin.volkswagen.de/erwin/showCustomerRegistration.do
Some data is available.
http://www.dieselschrauber.de/Solldaten_Main.html
The status of the clutch switch likely also appears here in block 6, value 2, along with the status of the two brake pedal switches.
There are two values for the accelerator pedal, as there are two potentiometers.
Translated on 11-07-2026, 7:43.
Httpbox
Post11-10-2015, 20:33    Subject: Golf IV, 90 HP TDI, 2002, silly mistake Quote
Here are the next logs.
Hopefully, the right ones.
LOG-01-019-001-xxx.CSV
 File name:  LOG-01-019-001-xxx.CSV
 File size:  28.8 KB
 Downloaded:  343 times
LOG-01-017-062.CSV
 File name:  LOG-01-017-062.CSV
 File size:  1.27 KB
 Downloaded:  279 times
Translated on 11-07-2026, 7:44.
Post11-10-2015, 20:46    Subject: Quote
The values look okay. Please log the engine speed, throttle position, and voltage at the control slide again, if possible, using the "Turbo" button (if available, it will appear on the corresponding screen).
Und versuche das von Dir beschriebene Problem zu provozieren. Es nutzt nichts, sinnloses Gegurke aufzuzeichnen wo alles ok ist. Wichtig ist das, wo es nicht ok ist. icon_idea.gif
Dein Log wo Du das schon aufgezeichnet hast weiter oben, enthält leider zuviel anderes Zeug, so daß die Abtastrate unterirdisch ist. Alle 2s ein Messwert ist für den Lokus. icon_wink.gif
Translated on 11-07-2026, 7:45.
Post12-10-2015, 9:04    Subject: Quote
So, let's go over it again:
- MWB 19 only activates when the ignition is on; in addition, MWB 1 is required.
- MWB 1 at idle speed, plus accelerator pedal position, clutch switch;
Is that really so difficult?
Translated on 11-07-2026, 7:46.
No new posts P2006 - Intake manifold control valve stuck closed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wind Noise in Audi A2 (8Z0) 2002: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, HVAC failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf III TDI doesn't accelerate smoothly Diesel Engine Technology
No new posts TDI Golf IV: Engine Misfire, 96 kW, 2002 Diesel Engine Technology
No new posts Golf IV TDI: Buying Guide for 90 & 101 HP Models Diesel Engine Technology
No new posts AGR at 100% - Performance and Optimization On-Board Diagnostics (OBD)
