Boost Pressure Build-up: ARL Values Needed
g1om
Post26-11-2015, 9:44    Subject: Boost Pressure Build-up: ARL Values Needed Quote
Find the boost pressure values of original ARL engines that do not exhibit any error codes. icon_rolleyes.gif
I personally drive a 1M Leon.
She would like to compare her results with my measured values.
There appears to be a problem with the ventilation.
Perhaps someone here can help me with this.
Thank you very much.
Translated on 05-10-2026, 0:41.
dieselschrauber likes this.
Post26-11-2015, 10:56    Subject: Boost Pressure Build-up: ARL Values Needed Quote
Here is a log image of a functional 1M ARL with factory software: speed, load demand (actual), luminous intensity, and low-level torque.
Edit: The logs were transported in the fourth gear.
 File size:  13.45 KB
 Viewed:  1021 times
Translated on 05-10-2026, 0:42.
g1om
Post26-11-2015, 13:00    Subject: Boost Pressure Build-up: ARL Values Needed Quote
Thank you, Ulf, for the log image.
At first glance, it looks completely different from mine.
I am particularly interested in the area of LD (likely referring to a specific technical term), and the duty cycle associated with it.
Unfortunately, I can't determine what the TV's maximum brightness should be.
I have a relatively constant value of 65% here.
In my image, I used both very aggressive overbites and, in some cases, severe underbites.
Translated on 05-10-2026, 0:43.
Post26-11-2015, 13:45    Subject: Boost Pressure Build-up: ARL Values Needed Quote
Here's a dyno graph of my ex-BUK engine (330Nm / 160PS in a Seat Ibiza 6L), also in 4th gear. It shouldn't differ significantly from an ARL engine.
Note: The TV curve in my logs is inverted, meaning that to compare it with your log data, you need to calculate "100 - my log value". Around 65% in the mid-RPM range should be acceptable.
 File size:  9.27 KB
 Viewed:  506 times
Translated on 05-10-2026, 0:44.
g1om
Post26-11-2015, 15:31    Subject: Boost Pressure Build-up: ARL Values Needed Quote
Now I'm in a fix icon_twisted.gif because after I experimentally shortened and lengthened the thread length on the LD sensor, the LD image is getting worse and worse.
Overshoot/undershoot and significant smoke development during the adjustment process.
I think the loader is going to be removed now.
Translated on 05-10-2026, 0:45.
hame22
Post03-12-2015, 21:26    Subject: Boost Pressure Build-up: ARL Values Needed Quote
Have you checked if the rod might be stuck or moving abruptly?
Translated on 05-10-2026, 0:46.
No new posts Erwin - Looking for a repair manual for VAG vehicles Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Differential Pressure & Backpressure: 3.0 TDI Comparison Diesel Engine Technology
No new posts Boost Pressure Build-up 2.0 CR On-Board Diagnostics (OBD)
No new posts Ansprechverhalten bzw. Ladedruckaufbau Diesel Engine Technology
No new posts Boost pressure build-up carrier, AXR Upload
