P2293 - Fuel Pressure Regulator Valve (N276), Mechanical. Error (Solution)
Post02-02-2016, 12:25    Subject: P2293 - Fuel Pressure Regulator Valve (N276), Mechanical. Error Quote
Possible causes for P2293, Fuel Pressure Regulator Valve (N276), Mechanical Failure:
- Low fuel pressure (cannot be adjusted to the target pressure).
- Fuel pressure control valve (N276) mechanically defective.
Specifically, in 2.0 TFSI engines, the cause can be a worn camshaft that drives the high-pressure fuel pump, resulting in insufficient fuel pressure and the inability to regulate the fuel pressure.
Ratings - P2293 - Fuel Pressure Regulator Valve (N276), Mechanical. Error
No new posts Caddy Bj 07 BLS AGR Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.4 TSI Error Fuel Pressure Regulator Valve Gasoline Engine Technology
No new posts Mechanical & Electronic EGR Valve Deactivation Diesel Engine Technology
New posts Question regarding a 2008 Touran, 1.4 TSI BMY, won't star... Gasoline Engine Technology
No new posts AGR errors On-Board Diagnostics (OBD)
